Window lift motor
- Junior Member
- Full Name: David Root
- Nickname: Dave Root
- Home Town: Melville
- Current 4x4: The Hippobeast! 1998 Nissan Patrol 4.2D with Michael's turbo conversion magic!
- Been thanked: 2 times
Window lift motor
Does anyone have any leads on where I can source a window lift motor for a Y61 - rear passenger size. I'm balking at the R6k plus quote from Nissan! Happy with a salvaged/reconditioned part.
Thanks.
Thanks.
Re: Window lift motor
Hannes kroone can help he is running dawid spare parts while he is away i will phone him quick for you
- Junior Member
Thanks Tinus,
That would explain why Dawid did not respond to an facebook message I sent him!
- David M
- Full Name: David Marais
- Nickname: David Marais
- Home Town: Midrand
- Has thanked: 20 times
- Been thanked: 97 times
Those don't often break but the switch does which makes the window go slow or stop completely. Check as you may just need the switch.
- Junior Member
It was a consequence of being submerged!
Switch is fine and was also replaced. It is definitely the motor.
Ok ...Ok.... you cannot tell us a teaser of a story and then stop........ What the hell happened???
So did I, behind the ears, but I'm still working.....hahahahaha
- Junior Member
Let’s put it this way, we renamed her the Hippobeast because she seems to prefer being submerged most of the time...
