TB48 Condenser Fan Hack for high-speed.
- vanhack
- Full Name: Siddharth Patel
- Nickname: Sid
- Home Town: Dubai, UAE
- Current 4x4: Y61 LWB Patrol TB48E, Auto
- Has thanked: 36 times
- Been thanked: 24 times
As temperatures are rising worldwide, or hot periods becoming longer months per annum and hours per day, the cooling systems are not coping with these new temps.
My 4.8, which probably had it's design in 2003, or before has issues cooling the cabin when not moving in traffic, as there is not enough airflow over the condensor when fans are at low speed in the summer months here. We will have 40+C everyday for the next 4 months, just recieved a temperature warning from the fire department that it will be 47 to 50 for the next 4 days. I have instaled a winch, and front light bar with slim LED light, but on a stock bumper, which might also hamper air flow.
Anyhow from the diagram from the workshop manual below on what conditions will switch on the condensor fans to low, and to high speeds, I took the vehicle's coolant temp to 100C, and the fans switched to high speed, and this cooled the cabin.
Having the fans on high speed definitely makes a considerable difference in AC cooling, so I want to hack into the high speed relay, I think relay number 3, and have my own switch to use from the cabin. I am concerned that If I use a 12V battery signal, to the relay's input, that I might be putting too much voltage into that wire, and backfeed 12V to the ECM? Can you confirm whether I am right not to do this, or the ECM send a 12V signal anyhow?
- cooling_fan_relay1.jpg (94.25 KiB) Viewed 7950 times
- cooling_Fan_condition1.jpg (92.52 KiB) Viewed 7950 times
- Has thanked: 1134 times
- Been thanked: 1044 times
Re: TB48 Condenser Fan Hack for high-speed.
I am not really too clever with this, but I don't think you can put too much power into the relay.
However, it may be safer to just install an additional relay directly to the fan?
Interesting!
I will be watching this one.
- Full Name: Jacques Steyn
- Nickname: AceVentura
- Home Town: Durbanville
- Current 4x4: '08 Nissan Patrol 4.8 GRX
'96 Ssangyong Musso 602EL TD Executive - Home Language: Afrikaans
- Has thanked: 3 times
- Been thanked: 7 times
Soooooo, are you still watching JP?
When nature calls
Jacques Steyn
2008 Nissan Patrol 4.8 GRX A/T (190kw)
Tough Dog Suspension | Outback Extreme Rear Replacement Bumper | Ironman Front Bumper
Air Helpers | Snorkel | Frontrunner Roofrack
Wishlist: TPM, Seat covers, drawer system
Jacques Steyn
Just added a direct 12v to fan toggle switch on the dash... if it is hot & I'm crawling in traffic it gets flipped, seems to help a bit.
- vanhack
- Nickname: Sid
Super, so 12V direct to which wire on the fans wiring?
Used the passenger side fan, just ran a wire direct to battery with a switch on the dash. Will see if I can load some pics later.
JP... I hope you fused that power feed !!!
