So my old GQ is up for sale - this is the info I have in the vehicle:
I procured it in 2012 with the mileage at that stage on 233 000km.
The following was done between 233 000 and 238 000km:
New clutch fitted
Starter was re done
Alternator was re done
For the Mileage of 238 000 to 242 000 the following was done by Graham from G tech
Replaced / repaired:
Full OME suspension
• Front & Rear Nitro Sport Shocks,
• Front and Rear 250KG coils,
• Steering damper,
Gearbox Packer Kit
Carter Kit
Serviced clutch slave cylinder all new rubbers and seals
Repaired Clutch hydraulic pipe
Fitted new clutch fork boot rubber
Exhaust rubber
New drag links
Wheel Alignment
All Caster bushes
Fixed Gearbox leak and topped up
Secure Centre console
Overhauled Carb with new jets
Soldered all wire connections
Fixed head lights wiring and steering switch (all lights work now – parks, normal and high beam)
Sealed head lights
New rear swaybar links
New rear swaybar bushes
Rear OME swaybar extension brackets
All belts replaced, fan, aircon and power steering
Replaced 4 body mounts
Replaced both front manual locking hubs
Replaced driver door central locking
New air filter
Long range tank leaked, replaced with original. (80L)
Rear door lock adjusted
Extras on the vehicle:
Aluminium Bulbar
Full roof rack with extension
Self made Drawer system with fridge slide viewtopic.php?f=43&t=4157
Front diff protector
Front ARB locker
Rock Sliders
Seat covers
Radio with amp
270 custom awning (Peter Conan)
80mm lift
Floor mats front and rear
Gullwing with kitchen
National Luna Dual Battery system with control / monitor
100A Alternator
Rear Factory Diff Lock
Cooper AT3 on Mikey Thompson mags 70% left
Tow bar
Air suspension in rear
Charging point in rear.
Night breaker globes for head lights
Added rear LED working light
Dash Cover
2x rooftop tents
Floor of the vehicle was fitted with Dynamat, sound proofing.
Carpet was replaced with Vinal carpets for ease of clean.
4 Doors also re-upholstered
Die extra’s on the vehicle is in excess of R100,000.
The vehicle is privately owned, and used as a holiday vehicle. Currently on 250 000KM
Vehicle in Krugersdorp
R90k - negotiable
95 GQ 4.2 SGL for sale
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Has thanked: 193 times
- Been thanked: 275 times
- 279a.jpg (172.57 KiB) Viewed 3334 times
- 278.jpg (153.3 KiB) Viewed 3334 times
- 123a (1).jpg (372.51 KiB) Viewed 3334 times
- 116.JPG (318.71 KiB) Viewed 3334 times
- Gold one
- 20150704_142948.jpg (4.25 MiB) Viewed 3334 times
- Full Name: Fanus
- Has thanked: 244 times
- Been thanked: 219 times
Re: 95 GQ 4.2 SGL for sale
VERY tempting....
just the cost of petrol that is holding me back.
