Bush-Cab Roofracks
If you supply and/or install equipment or accessories for Patrols, then please tell us about your business.
IR_Eddie
Full Name: Eduard groenewald
Nickname: IR_Eddie
Home Town: Cape Town
Current 4x4: Patrol 4.8 GRX ('07)
Has thanked: 18 times
Been thanked: 8 times
Bush-Cab Roofracks
Post by IR_Eddie »
Anyone have experience with Bush-Cab roofracks. they are in Stikland (CPT) and just gave me a qoute for a new roofrack for R5K.
https://www.bushcab.co.za/index.php/roof-racks/
pgreeff
Full Name: Paul Greeff
Nickname: Paul
Has thanked: 24 times
Been thanked: 56 times
Re: Bush-Cab Roofracks
Post by pgreeff »
Never heard of them. I can't say that I like the look of their roof rack, although it appears functional and very sturdy. But their drawer systems and canopies look very neat.
2004 Nissan Patrol 4.8
JTEC
Full Name: Jade Dafel
Nickname: JTEC
Home Town: Somerset West
Has thanked: 164 times
Been thanked: 64 times
Post by JTEC »
Im guessing these are steel which is extra weight. Just something to consider when calculating max load weight.
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
IR_Eddie
Nickname: IR_Eddie
Post by IR_Eddie »
JTEC - They use Alu. but I have not been to their facilities to check it out.
Have to agree on the look based on their website. it looks like a home made roof rack for a plumbing bakkie and not very well finished off.
JTEC
Nickname: JTEC
Post by JTEC »
IR_Eddie wrote: 24 May 2019 10:21 JTEC - They use Alu. but I have not been to their facilities to check it out.
Ok thats quite decent then. The look is not great but if powdercoated black will look much better. Maybe you can specify fitting points custom to your setup?
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
IR_Eddie
Nickname: IR_Eddie
Post by IR_Eddie »
I'll go around to the shop sometime and give some feedback.
I don't like the square corners. Also the load bars does not look wide enough from the photos and the spacing seems a bit far apart.
JTEC
Nickname: JTEC
Post by JTEC »
IR_Eddie wrote: 24 May 2019 10:37 I'll go around to the shop sometime and give some feedback.
Thanks, feedback will be great. :thumbup: Im guessing those pics might just be of a generic build for show and not specific to the Trols but lets see. Would be cool if you can specify you layout.
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
IR_Eddie
Nickname: IR_Eddie
Post by IR_Eddie »
Its definitely not for the Trol. They don't have the dimensions and I need to take it in for measurements. I am sure I will be able to ask them to custom it a bit more to my needs.
IR_Eddie
Nickname: IR_Eddie
Post by IR_Eddie »
I quickly stoped by there workshop and was pleasantly surprised. the quality looks much deferent from the ones on the website. The lead time is about 2 weeks and they custom it to your needs including the spacing etc... they can also powder coat it in black. They can also make variouse brackets and attachments to your needs.
below is some pictures.
JTEC
Nickname: JTEC
Post by JTEC »
Thanks Eddie, :goodpost: that actually looks really good. and R5k ?? Its got my attention
How was the weight? Also only the other thing is mounting, what about the gutter feet?
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
Return to “22. 4x4 Suppliers/Installers”
