Y61 4.2 Rear knocking noise
Tiny Howarth
Full Name: Graham Howarth
Nickname: Tiny
Home Town: Walvis Bay
Has thanked: 28 times
Been thanked: 23 times
Post by Tiny Howarth »
Rear Nocking Noise when driving in sand, on the road no noise, cannot say where in the rear, anybody have any ideas
Re: Y61 4.2 Rear knocking noise
Mabe the rubber packing on top of the coil is worn ?
Been thanked: 473 times
Or the upper and lower rubber bushes might be "kaput", so as you go over a bump it has excess movement. You should also feel it on pull off though....
pgreeff
Full Name: Paul Greeff
Nickname: Paul
Has thanked: 24 times
Been thanked: 56 times
Post by pgreeff »
One of the rubbers on my rear sway bars disintegrated. The sway bar had a lot of play as a result and any drastic movement, such as going over a speed bump would result in a loud clack sound.
I've also had two of my shocks on different cars develop knocking sounds. It was a major pain to find since the shock tested fine. Could have been the mounting rubbers as well I suppose. Either way, replacing the shocks sorted the problem in these two cases.
2004 Nissan Patrol 4.8
Tiny Howarth
Nickname: Tiny
Tinus lotz wrote: 24 May 2019 06:28 Mabe the rubber packing on top of the coil is worn ?
Thanks good place to start, I have fitted OME recently, made noise before as well.
Tiny Howarth
Nickname: Tiny
ricster wrote: 24 May 2019 09:00 Or the upper and lower rubber bushes might be "kaput", so as you go over a bump it has excess movement. You should also feel it on pull off though....
HI thanks for input, no noise on pull off.
Tiny Howarth
Nickname: Tiny
pgreeff wrote: 24 May 2019 09:43 One of the rubbers on my rear sway bars disintegrated. The sway bar had a lot of play as a result and any drastic movement, such as going over a speed bump would result in a loud clack sound.
HI, I have recently replaced coils and shocks OME 2", made no difference, going over speed humps does not make a noise.
Craig Lord
Full Name: Craig Lord
Nickname: Craig
Home Town: Tuli Block
Has thanked: 97 times
Been thanked: 60 times
Post by Craig Lord »
Check the sway bar links to see If any of them are loose. Mine keeps coming loose on the rear passenger side and any articulation results in a loud knocking noise because of the play. Drives me crazy QQQ it's fine on the tar but as soon as I go off road it starts.
I need to get new ones next time I'm in SA
When in doubt throttle out !
4.8 GRX Patrol (sold)
Tiny Howarth
Nickname: Tiny
Craig Lord wrote: 25 May 2019 11:08 Check the sway bar links to see If any of them are loose. Mine keeps coming loose on the rear passenger side and any articulation results in a loud knocking noise because of the play. Drives me crazy QQQ it's fine on the tar but as soon as I go off road it starts.
Thanks I will check this out.
