Compressor hose
Sweetlips
Full Name: Lawrence
Nickname: Sweetlips
Home Town: Paarl
Current 4x4: 2006 4.8 GRX
Has thanked: 47 times
Been thanked: 99 times
Compressor hose
Post by Sweetlips »
Gents
Where in the Western Cape area can you go to make up a hose like this?
Compressor hose.jpg (133.65 KiB) Viewed 3974 times
Tunja
Full Name: Ernest Tunnah
Nickname: Tunja
Home Town: Swakopmund
Has thanked: 9 times
Been thanked: 18 times
Re: Compressor hose
Post by Tunja »
Lawrence, any good engineering hardware / accessory shop will have that type of hose (google Apple store in the Strand industrial) or even hydraulic shops.
But why do you want to be stuck with such a long piece of hose in your Troll? Unless its for use at home and hung on a wall that hose is way too long.
Rather find those "suzi" hoses that trucks use for air brakes but the smaller diameter ones, they take up little room and if you need extra length then buy 2 and have quick dis-connect fittings on them. Midas or Auto Zone should sell the loose spiral Suzi pipes with connectors on.
This is my set up and i can reach all 4 wheels with it - that pipe can stretch...
SCUBA Patrol
Full Name: Phillip Jacobs
Nickname: Phillip
Has thanked: 31 times
Been thanked: 32 times
Re: Compressor hose
Post by SCUBA Patrol »
Lawrence,
I agree with Tunja, you should find the "suzi" type coiled hose at most hardware stores that stock pneumatic equipment and parts. Make up the rest of what you need from there.
on a side, Tunja, shorten the compressor's electrical cord to 500mm and connect directly to the battery and you will get better performance out of it. You have the long hose to get to all the tires from the front of the car!
Phillip
2006 3l with MADMAN
Sweetlips
Full Name: Lawrence
Nickname: Sweetlips
Home Town: Paarl
Re: Compressor hose
Post by Sweetlips »
Gents
I will have to purchase a new compressor for me in any case and generally they come with those springy hoses.
I have a spare of those already i just hate how they pack up afterwards.
The idea wasn't to have a very long hose it just seemed easier to store.
Maybe i'm over complicating my life in excitement lol.
Tunja
Nickname: Tunja
Re: Compressor hose
Post by Tunja »
SCUBA Patrol wrote: 11 Apr 2019 15:20 Lawrence,
Phillip, yes it gets "hot" pumping 285 Muds up, yes i connect directly to the battery and always run the engine - can't believe the amps these pump pull! and on 1 occasion even blew the fuse - don't ask :rolleyes: So I should shorten the cables for sure but then will need a extra suzi hose. Life is always a compromise...
Tunja
Nickname: Tunja
Re: Compressor hose
Post by Tunja »
Sweetlips wrote: 11 Apr 2019 15:37 Gents
Hahahaha yep, next time I buy I will go for the twin head 160L / min compressor, this 80L just takes too long
SCUBA Patrol
Nickname: Phillip
Re: Compressor hose
Synde ek ook 'n nuwe kompressor moet aanskaf, wat dink jullevan die een?
https://www.bidorbuy.co.za/item/4081946 ... lator.html
wat ek van hom hou is die 8liter tenk wat dit moontlik maak om 'n band te kan re-bead? Ook om ander lug toerusting te gebruik soos 'n blower ens.
Ja die 70l/min kompressor mag dalk bietjie lig in die broek wees, maar sal die job kan doen, en ja ek is bewus van die gevare van "pressure vessels" aangesien ek 'n gekwalifiseerde kompressor operateur is vir hoëdruk silinders (230bar +) in die scuba duik industrie.
Sal graag julle opinies wil hoor!
Patrol groete
Phillip
2006 3l with MADMAN
Re: Compressor hose
SCUBA Patrol wrote: 30 Apr 2019 10:03 Synde ek ook 'n nuwe kompressor moet aanskaf, wat dink jullevan die een?
Patrol groete
ek sien hy het n vessel en druk skakelaar ....mens nodig dit nie vir wiele pomp nie
