Patrol 3.0 GL, Mechanic
AndrewA
Full Name: Andrew Anderson
Nickname: AndrewA
Home Town: Kensington, Johannesburg
Current 4x4: Patrol GRX 4.8, 2010
Been thanked: 12 times
Post by AndrewA »
Looking for an experienced Patrol 3.0 GL diesel mechanic, if anybody can recommend one to me please let me know. Thanks.
Re: Patrol 3.0 GL, Mechanic
Andrew, I would say that Michael from SoJo Automotive would be the best bet, or Graham from G-Tech. They are our resident Patrol gurus up here in Gauteng. What seems to be the issue with the 3.0 Patrol ?
AndrewA
Nickname: AndrewA
Post by AndrewA »
At this stage it looks like a compression problem, Nissan checked it on it's standard service. I would like a second opinion and depending on that result decide if the motor needs to be opened and repaired.
Rodney
Full Name: Rodney Smith
Nickname: Rodney
Home Town: Port Elizabeth
Current 4x4: 2013 3.0D GL
Been thanked: 10 times
Post by Rodney »
Another opinion essential. Hopefully not serious. Neighbour on my east compression problem small sedan 6 months out of warranty. Franchisor analysis (via computer) R111K to recondition. Ended up burnt valve plus all that goes with removing the head and R32K. Neighbour on my west different manufacturer LDV 250,000 Km poor compression. Franchisor analysis (not sure how checked ) could only diagnose after opening engine - put down R65K deposit to open engine. Ended up to be a serious computer problem that could have destroyed the engine with ongoing use. Computer repaired in the cape - all in was R40K. He has done over 75,000km since then and all appears good. Bottom line franchise mechanics are (mostly) dependent 100% on what the computer tells them.
Andrew, if it was my vehicle, I would be comfy sending it to either Sojo or G-tech. I know that neither of those 2 would bullsh__ anyone. They also cannot afford to mess up a really great relationship that they already have with the Patrol guys, as many many guys have their Patrols serviced and/or repaired by them.
Give them a call and chat with them. Graham may say Michael is the better person to do this or Michael may say Graham is the better person to do it. They all know each other well.
Let me know if you need their numbers.
Micheal has the tools to do comp test for you ....did it get hot at all?
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Has thanked: 179 times
Been thanked: 206 times
Post by Anthony Forgey »
Michael will do a pressure test and give his opinion. He is the diesel patrol man.
AndrewA
Nickname: AndrewA
Post by AndrewA »
Thanks for all the help I will contact one of them. I did not suspect anything becides in my opinion it was down on power when towing. Just went in for a standard service.
SCUBA Patrol
Full Name: Phillip Jacobs
Nickname: Phillip
Has thanked: 31 times
Been thanked: 32 times
Post by SCUBA Patrol »
You can also try SAC in Midrand, as it is a 3.0l and Micheal a 4.2 specialist (would like it if Micheal will be willing to look and work his magic on the 3.0l's)> Contact Greg Justice, (Juice on the forum) he has a 3.0l and will know of someone that can have a look for you as well.
Phillip
2006 3l with MADMAN
AndrewA
Nickname: AndrewA
Post by AndrewA »
