16" alloy rim for y61 wanted
Wayside
Full Name: EJ Watson
Nickname: EJ
Home Town: Benoni
Current 4x4: 2002 3.0 Di
Post by Wayside »
Looking for a 16 inch allow for a 2002 3.0di, preferably in GP but will courier of necessary. Please pm if you have anything in order to discuss costs.
Need a second spare in case the management decides to try parallel parking.
Re: 16" alloy rim for y61 wanted
HAHAHAHAHA :rolling: :rolling: :rolling: .... that is EPIC !!!!
I don't have a spare set of mags, but just for general info, make sure the ID of the rims you put on have a small radius ( i think its a 2mm radius ) due the the Patrol hubs having a radius on them and not a 90 degree where the rim and hub seat. This can turn out to be a catastrophic failure as you cannot seat the rim properly to the hub and I have seen a front wheel fall off while nice new 4.8 a few years back (luckily on a trail so wasn't going fast).
You are looking for a 2003 to 2004 16inch 4.8 mag .....
Are the 4.8 mag and the 3.0 mags the same?
Jip 2003 to 2004 models yes remember alex witbliz had it on also
