Air bag replacement
gupster
Full Name: Barry Guppy
Nickname: Baz
Home Town: Hibberdene
2005 Nissan Patrol 3.0 GR
Has thanked: 136 times
Been thanked: 31 times
Air bag replacement
Post by gupster »
Hi all.
I took my Patrol to Nissan in Port Shepstone today for that airbag recall. It took about 3 hour to do and afterwards the mechanic called me and showed me his Nissan diagnostic device could not find the EU. He asked me if it had been chipped as that would cause the problem but I dont know if it has been. Is there anyway to tell, something that is obvious. I know the chap I bought it from did not chip it and we cant get hold of the owner before him. There is nothing on the car either to say it has. I also wondered if the Mad Dog installation might cause that problem. I have successfully read the codes manually from the plug under the steering wheel so think that the connection there is ok.
Any thoughts??
Have Troll, will travel.
Re: Air bag replacement
I know nothing about the chips etc, but I would assume that one could simply do a visual check.... but again, never seen one....
gupster
Nickname: Baz
Post by gupster »
Thanks Cedric. Yes I have never seen one either but was hoping someone on the forum who has a chip and has had their air bag replaced would have replied if they had experienced something similar. Thats assuming though that it was tested with the Nissan Consult thingy.
I'm sure someone will reply soon.
Maybe change the subject title a bit to say something about "ECU Chip interfering with Airbag light" or something like that as there are quite a few Airbag replacement type posts already on and people may just skip over it.
gupster
Nickname: Baz
Post by gupster »
Thanks Cedric, a good idea. Will give it a couple of days and repost.
pgreeff
Full Name: Paul Greeff
Nickname: Paul
Has thanked: 24 times
Been thanked: 56 times
Post by pgreeff »
gupster wrote: 17 Oct 2018 17:18 Thanks Cedric, a good idea. Will give it a couple of days and repost.
That doesn't make sense. He should be able to find the ECU or pick it up regardless of a chip on the car. The chip would be a piggy back chip feeding bogus signals to the ECU so it doesn't error while managing the engine, but from a diagnostic perspective they should be able to pick it up. I love how the default question for any problem is, "did you chip it."
2004 Nissan Patrol 4.8
gupster
Nickname: Baz
Post by gupster »
Hi Paul, what you say makes sense otherwise Chipping would prevent future diagnostics of every chipped Patrol. Its the first time I had ever been asked that question and so ran straight to the forum for answers. I still wonder though if the wiring in of the Mad Man would affect the connection to the ECU, however that too would have thrown up a red flag with the forum.
Thank you
Has thanked: 1136 times
Been thanked: 1047 times
I can't see that the madman could affect the ECU in any way, as the madman installation is entirely separate from the ECU.
gupster
Nickname: Baz
Post by gupster »
Thanks Peter. Brian from Mad Man is going to send down a Boost gauge for the unit, when they arrive, and I will get the chap in Durban who does the installation to check it afterwards with his tester and report back on this post with the findings.
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Has thanked: 179 times
Been thanked: 206 times
Post by Anthony Forgey »
Like Peter said, the Madman is completely separate from the ECU. It wouldnt have any effect on whether the ECU could be read or not.
