Rear sway bar
- Full Name: Paul Greeff
- Nickname: Paul
- Has thanked: 24 times
- Been thanked: 56 times
Rear sway bar
Yup, that's within tolerance...
Do I just remove it till I can get around to fixing it?
2004 Nissan Patrol 4.8
- Been thanked: 1036 times
Re: Rear sway bar
Remove it. As long as you don't carry a pile of weight on the roof, you'll be fine.
I suspect I may have a second-hand rubber lying around if you want it.
- Nickname: Paul
Re: Rear sway bar
I will be grateful for it. Thanks Peter.Peter Connan wrote: ↑18 Sep 2018 17:18 I suspect I may have a second-hand rubber lying around if you want it.
- Nickname: Paul
Re: Rear sway bar
It took a while but finally the rear sway bar is quiet. Thanks for the replacements rubbers.
