Posts: 1339 Joined: 02 Apr 2009 14:34
Has thanked: 1046 times
Been thanked: 231 times
Post
by JohnBoyZA » 14 Jul 2018 12:04
I'm sure I saw a similar query on the forum, but can't find it. Had a problem with my passenger seat slider switch and would only move forward and not back. So I dismantled it and now I have an even bigger problem as the ball and springs went flying. I'm now missing a spring and ball
eish!
Anyone know where I can source a replacement unit?
Thanx
John
Posts: 1831 Joined: 12 Jan 2015 13:26
Has thanked: 451 times
Been thanked: 724 times
Post
by iandvl » 14 Jul 2018 13:24
JohnBoyZA wrote: ↑ 14 Jul 2018 12:04
eish!
Thanx
John
David Volschenk springs to mind (no pun intended)
If he cannot help, I believe I may be in the UAE for three weeks shortly, and I will probably be able to source one there...
Pieter B
Posts: 574 Joined: 29 Sep 2014 12:40
Full Name: Pieter Botha
Nickname: Pieter
Has thanked: 6 times
Been thanked: 97 times
Post
by Pieter B » 15 Jul 2018 11:16
Mine is also working intermittently. I was thinking to give it a go and take it apart as I had a good result with the window switch. After this I'll just look at replacement..
Posts: 7590 Joined: 29 Aug 2010 13:07
Current 4x4: Nissan patrol 4.8 GRX 2005 Toyota 2.7 legend 35 LWB 4X4
Has thanked: 802 times
Been thanked: 562 times
Post
by Tinus lotz » 15 Jul 2018 12:17
The seat covers kill them check the straps mine also stuffed out got one from scrapyard in kraaifontein
Post
by JohnBoyZA » 15 Jul 2018 15:52
Thanx Ian, that would be great ... pls let me know. Ja nee Pieter ... n ou het klein handjies nodig en baie geduld!
Post
by JohnBoyZA » 15 Jul 2018 15:54
Tinus, het hulle nog gehad? Sal more bietjie rond bel...
Post
by Tinus lotz » 16 Jul 2018 13:41
JohnBoyZA wrote: ↑ 15 Jul 2018 15:54
Jong Jasper het vir my gaan optel hulle het die hele cover saam gegee seat was stukkend ...so hulle het spares afgehaal
Post
by Tinus lotz » 16 Jul 2018 14:30
Marino kan van dubai nuwes kry vir 2900 s a het nie stock nie
Post
by JohnBoyZA » 17 Jul 2018 09:00
Dankie, het by Marinus bestel...
Posts: 3461 Joined: 10 Jun 2009 16:58
Current 4x4: 1982 Datsun Safari 2,8 aka LOBO; [1,300,000 Km verby !] '99 PATROL 4,2 diesel. 2012 Jimny [SWAMBO se Kantoor-toe]
Has thanked: 299 times
Been thanked: 160 times
Post
by Kagiso II » 17 Jul 2018 21:21
Kobus Pienaar se Patrol doen dit ook [1999 4,5 GRX] dan druk hy op die plastiek omhulsel en dan werk die pes weer .. maar net links, regs werk bakgat
