My GQ and its history.......
Has thanked: 198 times
Been thanked: 280 times
So I had some time to kill and thought I can see how much info I can get off the forum regarding my Patrol.. so here goes!!
The Patrol was bought new in 1996 from Nissan by Grant's father - 95/96 ST4.2D that was imported from Aus by IC Nissan in Springs. Nissan SA keep telling that troll is a grey import. The story changes when I show them the original sale doc.
96 ST4.2 has a Safari Turbo & Intercooler fitted. This was done at 30 000km (Safari kit fitted at SAC in 99 when they were still the agents for Safari). The Ausie site quotes figures of 145 KW and 450 Nm.
A Front Safari intercooler. SAC het die sisteem in 97 opgesit - had the 76 mm exhaust on since 36k km
• Safari snorkel…
At 330 000km and 2009 Grant joined the forum and info obtained from 1600+ posts http://www.patrol4x4.co.za/viewtopic.ph ... lit=caffer
June 2009 - at SAC's got 82kW and 334 Nm on the wheels. Driving at 100 km/hr to 110 km/hr get 7.8 km/lt. Towing Safari trailer get 6.5 to 6.8 Km/l. The boost is set at .7 bar and their is lots of oompf when needed.
June 2009 - visited Uthuli, and they measured up the seats for a pattern. A week later they were fitted. R2300
July 2009 - The left rear disc brake has excessive wear on the inside, side. Also the disc is slightly warped ( clunking sound when driving) and a combination of the two problems caused the heat build up on the wheel.
Costs are a follows
R 1,500 a disc.
R 750 for brakes pads per side.
Source pads locally as Nissan do not have stock in SA. Troll has 337k on the clock and this will be the first replacement discs on the rear.
Sep 2009 - changed the discs, pads and found callipers in order. After cleaning the bolts(calliper mounting bolt) holding the calliper on, found one of them to be catching ever so slightly. Changed the bolts an bob's your uncle.
October 2009 - fitted pro white rims, painted black.
November 2009 – Water pump replaced, Fitted an EGT as well.
April 2010 - Lifting my GQ with a 90 mm XJS kit. The coils and shocks have been fitted, waiting for Panhard rods as the diff has moved around a 100mm to the right.
Castor correction kit is being fitted and should be in in a week.
Estimated lift from the OME 50 MM KIT IS N ADDITIONAL 100 MM.
August 2010 - Dyno at SAC Diesel is as follows, 360 000km
92 kW on wheels at 3000 rpm
376 nm at the fly wheel at 2200 rpm
November 2010 - spent R 4,100 for a clutch (had it's second clutch fitted at 345k km), pressure plate and thrust bearing from Nissan. It is an absolute must that the fly wheel get skimmed. Prior to the replacement I had excessive clutch juddering in first and second gear. Pressure plate was %$##%%^.
November 2010 - have 90mm gold Edition shocks(long travel) + coils + panhard rods, 3.5 deg caster correction and 100mm drop links for the anti sway bar.
Anything over 50 mm will require panhard rods, castor correction, extended barke lines and diff breathers as well as extended Swaybar links and extended bump stops.
November 2010 - Other mods to date are, Gull wings (3mm steel) in the rear windows, Cargo barrier, IPF spots on the roof rack, Upgraded crystal head lights with 90/100w globes from NARVA.
Rear wheel bearings did at 340k. Did discs, pad and bearings
April 2011 - took all the seats and carpet out. Took some IRB 420 heat resistant sheeting and covered the entire cabin, as well as the gear box area. Fitted additional felt to the front area...
July 2011 – SAC Diesel in Centurion got it's 370k km service. For good measure it also went for a Dyno,
Boost set a 9 psi
Power on the rear wheels at 3000 rpm 94kW
Torque at 2200 rpm 413 Nm.
Best results ever at 370k km. Only just run it.
November 2011 - Do a complete oil change ( everything that has oil in it) every 40 k km. Change the coolant and water every six months. Fan belts get changed every 30 k mainly because the belts runs directly under the radiator hose. Engine oil every 5000 km.
February 2012 - 378000km
Owner comment - engine oil filters and air filter get changed every 5000 km. Fan belts and fuel filter every 10 k km. In addition tot his changed over a period of 80 k km, all other oils and brake fluid, changed the radiator hoses top and bottom every 80 k km.
Radiator goes in to be flushed every 80 k km as well. Wheel bearings and greasing every 10 k km. I change them every 50 K km.
For engine services my car only goes to SAC Diesel. They only work on the engine and it get a dyno run and setting every 15 k km.
April 2012 - Interior lights have been changed to LED
August 2012 - New three core radiator is ready to be fitted to truck. Better flow and volume is larger.
October 2012 - TENESOL 90 W panel fitted under the roof rack. Also a STECA PR 1010 digital regulator.
November 2012 – Front PC diff guard – 384k km
March 2013 - Just fitted power brake front discs and pads to the Troll
April 2013 - 397K KM
September 2013 - got a dual charger with two usb chargers from O/D warehouse. Pulled a cable in from the battery through a new fuse box installed at the battery. had a switch installed as well so I could also switch of the power supply when not needed.
October 2013 – SAC fitted oil cooler.
November 2013 – Patrol up for sale R130k, then not for sale…..
February 2014 - Troll got new master cylinder (Nissan) and also got the callipers overhauled and cleaned. New rear brake shoes and brake fluid.
July 2014 – 405k km - 405 000 km service and all is well. - Compression in spec, injectors in order, and power and torque as normal.
August 2014 - new custom bumper, removed the lights off the roof rack to be legal. Now have round 51W led lights on the bumper.
Fitted the Cetek DC to DC with two 95 amp hour battery's on a customer slider behind the rear seat.
Sep 2014 - New head lights have arrived
Here are the specs on the new lights:
2800 Lumens on Low Beams
4450 Lumens on High Beams
6000K Colour
April 2015 – Patrol up for sale R115k
June 2015 – Sold to………… ME. 
July 2015 – Change back to 33/12.5/15 muddies.
Sep 2015 – Upgrade Front bumper with bars to protect lights and radiator.
Jan 2016 – Fit howling moon double rooftop tent.
Feb 2016 - Full service (415,692km), Adjust front wheel bearing, re-connect Mad man, grease propshaft, check and test alternator (GTECH)
March 2016 – fit new headlights, Spray mags black as well as bottom of Patrol. Rear ladder and bush bars fitted.
August 2016 – Put maps on car and cover with Plasti dip
October 2016 - Full service (423,600km), Rear diff oil, front diff oil, Gearbox oil, Transmission oil, Replace break fluid, front brake pads, Replace anti freeze.
July 2017 - Custom shocks front and back from Mikem - Bilstein. new Bumpstops front. Replace rubbers on sway bars
2017 – Fit rear camera and vintage horn.
March 2018 – Fit additional fuel tank 40L.
March 2018 - Full service (432,197km), Replace all belts, Replace clutch booster, Bleed brakes (Sojo)
June 2018 – (SOJO)
434 0101km
  • Replace clutch and fork rubber
    Skim Fly wheel
    Diesel pump calibrated
    Injectors reckoned
    New draglink
    New steering dampener
    Front and rear brake pads
    New sway bar links front and back
    New engine mounting
    Service starter
June 2018 – TLC http://www.patrol4x4.co.za/viewtopic.php?f=48&t=7881
July 2018 – more TLC - http://www.patrol4x4.co.za/viewtopic.php?f=48&t=7946 (Anthony)
New oil pressure switch
New headlights with LED globes
New rear speaker pods
VOD Boost gauge fitted
Madman re wired and moved
New dash pod
General electric service of wires etc
Sound system upgrade/service
New EGT probe
Fix electric window passenger side
Electric mirror switch relocated
Custom cup holders
Fit sound deadening in outer and inner door skin and foam liner in 4 doors
Fixed rev counter
Fixed hand brake
July 2018 Fit new seat covers and TPMS
Oct 2018 Rear wheel bearing & seal, side shaft seal - SOJO
April 2019 Other rear wheel bearing & seal, recon brake caliper - SOJO
February2020 - SOJO
450 000km
Replace Manifold bolts
Recon remaining 3 brake calipers
Replace rear side shaft seals
Replace front brake disks and pads - Terrain Taimer
Service front wheel bearings
Diesel pump top cover leak fixed
New radiator
Recon/service Turbo
Replace all belts - Terrain Taimer
Replace all hoses inc heater hoses - Terrain Taimer
Recon and balance Balance prop shaft
Service diffs
Replace handbrake cable
Full service
February 2020 - ANT
Serviced winch
New controller and solenoid box
Replace cable with synthetic
May 2020 - ANT
Fitted new Bluetooth radio.
July 2020 - ANT
Fixed gullwing and replaced all gas lifts on gull wings
Updated all solar to Blue Brad Harrison plugs (8)
2x Fridge slides - spring latches attached
Bonnet gas lift conversion done
August 2020 - SOJO
454 500km
Fitted new set of 33x12.5x15 General Grabber muddies
Oil change
Replaced tie rod ends
March 2021 - Badass Customs / Raptor SA
454 814km
Raptor painted full vehicle
March 2021 - SOJO
456 800km
Fit new suspension bushes - Trailing Arm Upper & Lower Rubbers
April 2021 - Myself
Power (12V) distribution box
June 2021 - Ants
457 951km
Repair and recon Alternator and spare alternator
July2021 - SOJO
458 803km
Fit new front manual hubs
July2021 - Ants
458 858km
Rear Coils from Terrain Tamer - 500kg
25A National Luna DC/DC with monitor
108A Blue Nova Lithium battery
Brad Harrison plugs fitted to Gullwing to connect rooftop tent to vehicle
September2021 - SOJO
459 648km
Full service
Replace Radius Arm bushes and radius arm to chassis rubbers
September 2021 - Ants
459 703km
Front coils Terrain Tamer
November 2021 - Ants
462 010km
Fit new Victron Smart Blue 15A charger
Fit circuit breaker to Aux battery supply, to isolate LiPo battery
Fit new battery clamps
April 2023 - Ants
470 050km
Vehicle services - Change oil filters, Oil Fuel filter and Oil
Vehicle services - Drain and replace rear diff oil, New Diff drain Plug R 245
Vehicle services - Drain and replace gearbox oil
Vehicle services - Drain and replace Transfer case oil
Vehicle services - Replace aircon tensioner pulley bearing
General Electrical Services - Fit supplied headlights, New grille clips, Wiring Indicator circuit to suit
General Electrical Services - 1 troubleshoot and repair rear right indicator, Fit Indicator globe holder
General Electrical Services - 1 Winch remote spool direction change
Vehicle services - Drain, remove, clean and replace Clutch master Cylinder, Bleed clutch
May 2025 - Ants
475 954km
Vehicle services - Oil Change, no filters
BUSH KIT LEADING ARM FRONT & CENTRE 4 X BUSHES
Custom Item - 12mm swaybar links with Rose joints x2
BUSH - LINK ROD STABILIZER BAR x4
Fuse holder and fuse
Drain oil and fill with new oil
Fit new fuse holder
Make new cable from fuse holder to New isolator
Modify unused bracket to fit new isolator
Fit new terminal on cable to dual battery
Mount Isolator
Fit swaybar link bushes to rear links
Fit new radius arm bushes
Tighten LHS and RHS wheel bearings
Replace steering damper bushes Panhard rod side
June2025 - Ants
478 804km
Repair rear brake carrier slide pins
Remove carrier
Clean rust from slide pin sleves
Clean corroded slide pins
Fit new dust boots where needed
Grease slide pins
Bleed rear brakes
September2025 - Ants
478 900km
Service TD42 Oil+Oil Filters+Fuel Filter+Filter oval
Fit shunt and modify ground cables to suit
fit and wire Victron display in gauge pod on dash
Fit new 10mm cables with victron charger plug from starter battery to rear cabin
Fit and rewire spotlights to bumper
Repair driver's door seal
Adjust rear barn doors
fit new front diff breather hose
replace Fast idle solenoid vacuum hose
Fit new bonnet shocks
Remove tie rod and fit new tie rod ball joint boot
Replace front brake hoses LHS and RHS
Bleed brakes
Bleed clutch system
Remove rear prop shaft, remove hand brake drum assembly
Replace leaking transfer case seal
clean handbrake assembly and fit new brake shoes
refit handbrake assembly and re fit prop shaft
Adjust handbrake
Flush and re-fill cooling system
Wheel rotation, balance and alignment
List of extra's on and in vehicle:
1. Safari Turbo
2. Oil cooler
3. Intercooler
4. Upgraded radiator
5. PC Bash plate
6. PC diff cover
7. 4 inch lift - 500kg constant rear coils and 150 smart progressive in front - Terrain Tamer
8. Bilstein shocks
9. Drop boxes
10. Pan hard rods
11. Extended sway bar links
12. Terrain Tamer Steering dampener
13. 270 Eezi awn awning…
14. Front runner roof rack
15. Cargo barrier
16. 90W Solar panel
17. Aluminium table
18. Stedi spotlights
19. Custom front bumper
20. Bush bars
21. Rear door ladder
22. Rock sliders
23. Gull wings
24. Custom bar built in
25. Custom Kitchen built in
26. Long range tank from Northern off-road - 136 lt SS tank
27. 40L aux tank
28. Terrain Tamer disks front
29. 65A Alternator
30. Spacers (trim packs) two 30 mm spacers on the top of the rear coils to help with the weight
31. 50 lt water tank in the back against the seats
32. 12V pump fitted to water tank with tap under rear bumper
33. 25A National Luna DC/DC with monitor
34. 15A Victron Blue Smart fitted with 220V power fitting
35. Outback Drawer system
36. Engel 40 & 42L fridge
37. Snow master 11L console fridge
38. 108A Blue Nova Lithium battery
39. 12500 lbs Warn which on a custom made winch plate
40. Winch cable replaced with rope
41. 160L Compressor fitted permanently in the rear
42. Compressor points run to left and right of vehicle for easy access
43. Madman
44. VDO boost gauge
45. Rear view Camera
46. Dash cover
47. VHF radio
48. UHF radio
49. 300W invertor
50. Custom build cup holders
51. Entire floor, fire wall and all 4 doors sound and heat damp fitted
52. Safari snorkel
53. Dummy lights in rear wired up
54. Canvas seat covers
55. External TPMS
56. Moremi rooftop tent with 12V lights, USB and cigarette lighter
57. 2 x 100W solar panels fitted to rooftop tent
58. Moremi drop down shower on slide fitted to roof rack
59. Gas Bottle, 60L water & gas shower fitted on roof rack
60. Power distribution panel(s)
61. 2x Floor panels that can replace rear seats when required
62. Dustbin that clips onto rear ladder
63. Rear wheel cover/or sandtrax
64. 76mm exhaust
65. Aftermarket mags
66. Custom wheel arches
67. Diff breathers
68. Rear door table
69. Cargo net fitted above rear seats
70. LED globes in roof lights
71. LED headlights with angel eyes
72. Gas shocks for bonnet
73. Raptor coated Patrol
74. Additional solar charger - lithium rated
75. Victron Smart Shunt
76. Stedi Spotlights
Uthuli Seat covers 1.jpg (129.95 KiB) Viewed 14812 times
Uthuli Seat covers 2.jpg (141.86 KiB) Viewed 14812 times
Uthuli Seat covers 3.jpg (138.73 KiB) Viewed 14812 times
Aug 2010 Kwik Awn.jpg (58.04 KiB) Viewed 14812 times
Aug 2010 MT with 285 75 16.jpg (60.91 KiB) Viewed 14812 times
Aug 2010 Outback drawer with drop slide.jpg (54.22 KiB) Viewed 14812 times
Aug 2010 Rock sliders with jack points.jpg (57.93 KiB) Viewed 14812 times
Aug 2010 TJM 110mm Lift with Panhard rods.jpg (44.35 KiB) Viewed 14812 times
March 2011 Patrol pic 1.jpg (162.25 KiB) Viewed 14812 times
Aug 2010 TJM Bar with KC spots.jpg (54.2 KiB) Viewed 14812 times
Aug 2010 Trol pic.jpg (56.32 KiB) Viewed 14812 times
Jan 2011 - 40L Engel fridge.jpg (42.15 KiB) Viewed 14812 times
Jan 2011 Bar unit with gull wing.jpg (46.99 KiB) Viewed 14812 times
Jan 2011 Cargo barrier.jpg (41.03 KiB) Viewed 14812 times
Jan 2011 Gull wing.jpg (39.89 KiB) Viewed 14812 times
Jan 2011 Kitchen with gull wing.jpg (36.85 KiB) Viewed 14812 times
March 2011 Patrol pic.jpg (66.86 KiB) Viewed 14812 times
Aug 2014 New custom bumper.jpg (112.71 KiB) Viewed 14812 times
Sep 2014 new headlights.jpg (55.27 KiB) Viewed 14812 times
Re: My GQ and its history.......
Pics
Some new additions to the Troll.
Sold the double rooftop tent, tried a clamshell and then got myself this Moremi Sport Hard top tent.
Added 2 x 100W solar panels to the tent, wired with 2x lights and usb sockets inside.
Replaced the cover of my awning as it had teared and the zip stripped.
Got myself one of those drop down showers fitted on the side of the roof rack, fitted to a Fernlock slide if I don't want the shower right next to the front door.
On the roofrack I fitted a gas bottel, 60L of water and an Alvava Gas shower.
So the GQ had some TLC in the form of a respray with Raptor.
Prep 2.jpg (248.3 KiB) Viewed 10037 times
Prep 1.jpg (233.63 KiB) Viewed 10037 times
Undercoat 1.jpg (225.4 KiB) Viewed 10037 times
Spray 4.jpg (114.46 KiB) Viewed 10037 times
Spray 3.jpg (122.1 KiB) Viewed 10037 times
Spray 2.jpg (149.56 KiB) Viewed 10037 times
Spray 1.jpg (98.8 KiB) Viewed 10037 times
Some more...
So the latest update was a DIY project that I decided to do myself.
Power distribution panel - with a Solar controller (backup to DC/DC just in case)
Also built in a small one at the back as one can apparently never have enough power points QQQ
Power back.jpg (253.35 KiB) Viewed 9528 times
Power panel.jpg (261.3 KiB) Viewed 9528 times
Long story short, my C-tek trickle charger moved on....., two 90A batteries moved on..... :doh: :doh:
So it was decision time, do I get another two 90A batteries and replace the C-tek or do I upgrade to current technology??????
After a lot of questions, and reading up on Lithium, I bit the bullet and updated my whole charging system - or should I say Ant's custom workshop :biggrin:
As always the work performed was of the highest quality, and installed the way I wanted it done as opposed to just straight forward.
Firstly got a 108A Blue Nova Lithium battery.
Replaced my C-tek 250S with the National Luna DC/DC which is Lithium ready, and the price at Bushpower included the monitor which was then a no brainer.
This was installed by Ant and worked a charm on the Goerapan trip and 9 day camping trip shortly after.
Next I did my research on the trickle charger that died and came to the conclusion that Lithium does not like trickle charging and neither does it like to be "stored" at 100% charged. So previously my system was set up that the C-tek was plugged in when the vehicle is not used and the charger would maintain the 2 90A batteries as well as my starter battery.
So now the question begged how do I have a system were the starter battery can be maintained without also giving charge to the Lithium battery.
Secondly, if I go camping and there is 220V I would like for everything to still run through my 12V system over an extended period without having to rely on solar as most places have nice spots under big trees or shade net and solar might not operate optimally, or I take a trailer and not the rooftop with attached solar panels.
Solution - Installed a 15A Victron Smart Blue charger which is directly connected to the Lithium battery (and not via the DC/DC as was previously the case), I can thus charge my Lit battery to full just before a trip, and also connect it to 220V at a camp site and it will keep the battery charged whilst I run fridges and lights from 12V over an extended period.
As for the main battery I will connect a 5A C-tek trickle charger to maintain it over periods where the GQ is not used. BUT, it must not charge the Lit via the DC/DC and here ANT installed a "circuit braker" for me that isolate the main battery from the second battery which allows me to use the trickle charge to just maintain the starter battery and as a bonus I can also now drive the Patrol and the DC/DC will not charge the lithium on short trips or if 12V charging is not required.
So now I have basically my 12V system set up in such a manner that I can charge via Alternator, 220V, Solar and all systems are separate from each other and I can chose when or what system will do the charging.
Lastly I replaced my backup/separate solar charger with a new solar charger that is also Lithium specked.
DC charger.jpg (282.07 KiB) Viewed 8482 times
Circuit braker.jpg (271.42 KiB) Viewed 8482 times
15A Victron charger.jpg (237.86 KiB) Viewed 8482 times
220V input.jpg (164.98 KiB) Viewed 8482 times
Just an update on the GQ
Had some major TLC from Ants customs the past few months (updated on post 1 were I log all that is done on the GQ)
As for the "extra's"
Had some - 2mm swaybar links with Rose joints x2 fitted to replace previous one's that was not working as well as intended.
The Lithium battery and setup ha been working a charm and spending 9 days in the Kruger I did not need to plug in to mains once for the duration of the trip.
The only difficulty, if one can call it that, is that the Lithium provides power for 90%plus of the time at a constant Voltage so it makes it almost impossible to know exactly what the charge rate or state of charge is upuntil it reaches the 90% discharge and then drops rappidly. So the question was how can I measure what goes into and out of the battery and see at what level of charge it is sitting.
Did some homework on the subject and decided that a shunt seems to be the answer to my questions. Bought the Victron 500A smart shunt and Ant's Customs was called upon - Fit shunt and modify ground cables to suit, and fit and wire Victron display in gauge pod on dash - Bob's your uncle and now I can see exactly what is going on with the 2nd battery on either the gauge mounted on my dash or if one wants to play around it is also Bleutooth connected through the app on my phone. As always Ant did a stellar job and all is neatly installed.
Also fitted a set of Stedi spotlights to front bumper with a nice low profile so no interferance with the airflow to the radiator.
Along with all the maintenance the GQ is ready to go for another few thousand worry free kilometre's.
