Help - Engine Parts
V75
Full Name: Johan Dalhuijsen
Nickname: V75
Home Town: Johannesburg, Fairland
Current 4x4: 1996 Nissan Patrol 4.2 Y60
Home Language: English / Dutch
Help - Engine Parts
Post by V75 »
Hi all
I need some help please. My 1996 Y60 4.2 Nissan Patrol is no longer a 1996. After 420.000 km and loss of compression and starting to use oil I decided to do an engine overhaul via one of my buddies (ex Nissan). He discovered that my car is (grey) import from the UK.
The Patrols of that era sold in SA did all come with a 4.5 or 4.8 engine, so I am probably the only 4.2 petrol Nissan Patrol in the country.
We can not find engine parts such as pistons, bearing etc for this engine.
Nissan SA has informed us that they can import them for us but a price tag of R30.000 is a bit much for my pocket
Has anybody go any suggestions or contacts???
Kind Regards
Johan Dalhuijsen
0825070706
Re: Help - Engine Parts
Johan, they are smoking their socks.
All the Petrol Y60's in SA have the 4.2 (TB42) engine. Mine had one too, but I have replaced it with a TB45, using the carburettor, inlet manifold and distributor from the 4.2. As a result, I did not need to modify the car in any way, except for having to fit an electric fuel pump. You can probably get a running 4.5 engine for around R15-20k, and do the same if you want. I can supply drawings for the adapter plate I made to fit between the cylinder head and intake manifold. Engine mounts, gearbox, clutch and exhaust manifold fit as is.
If you do want to re-build the TB42:
Bearings (both main and big-end) are the same as the TB45 and TD42. I have just re-built my TB45, and finding bearings was no problem. Pistons and gaskets also weren't a problem, although piston rings were a bit tricky, but these are different from the TB42.
Get hold of Pat at German Field Services, she supplied all the parts for my re-build.
You can get a sub and head complete for about 12k
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
you can contact me if you battling for spares etc...everything is available for those 4.2....
i can also get you a good second hand engine.
Full Name: SJC
Has thanked: 237 times
Been thanked: 203 times
Peter Connan wrote: 20 Jun 2018 17:03 Johan, they are smoking their socks.
En ek neem aan om td42 in te sit is meer gekompliseer?
Dis nie baie moeilik nie. Maar dit is redelik duur. Dit het my 3 jaar gelede net oor die R100k gekos. Ek is seker dit het ook nie intussen goedkoper geword nie.
Watse brandstofverbruik kry jou nou (vir watse tipe ryery) en het jy al die ding na Ant toe gevat vir 'n ordentlikke tuneup?
Full Name: SJC
4.3km/l in die dorp, maar die kar kry nie regtig kans om warm te word nie. My vrou se werk is 2km van ons huis af dan gaan haal sy kinders by die skool, nog so 3-4km se ry..
Het nog nie weer brandstof gebruik op oop pad getoets nie maar as ek reg onthou het ek laas jaar oppad rivertrip toe 5.7km/l gekry..(met dakrak en redrlik swaar gelaai)
Wens ek kon die kar by 🐜 kry, maar hys bietjie ver van my af...
As jy die kar so min gebruik gaan dit jou 'n dekade of meer kos om 'n TD42 conversion af te betaal.
Full Name: SJC
Nee ek weet.
Wonder maar net vir interressntheid wat alles gedoen moet word op n kar om van petrol na diesel oor te skakel.
Kon nog nie veel inligting hieroor opspoor nie.
RikusLouw
Full Name: Abraham HP Louw
Nickname: Rikus Louw
Home Town: Bellville
Current 4x4: '98 Toyota Prado Kzte Auto - 240k km
Has thanked: 1 time
Post by RikusLouw »
Daar is bitter baie wat gedoen moet word, natuurlik afhangende van die kar en watter motor jy wil in druk. Daar is 'n baie relevante reeks YouTube videos van Aussies wat nou 'n 80 series petrol vat en 'n 80 series diesel motor in druk. Mens sal dink dis redelik straightforward (want dis dieselfde maak, redelik eenvoudige meganiese en elektroniese komponente, ens),.dit is nie...
-Alles van die diesel sisteem vanaf waar die diesel ingegooi word tot waar die motor dit kry, moet verander word.
-Ongelooflik baie bedrading van die kar moet verander word, so die hele dash moet uitkom.
-Engine mounts, transmission mounts, struts, braces. 'n Spul van daai goed moet jy weg grind en op ander plekke vaswerk.
Daar is seker nog 100 goed wat mens moet doen, ek is die laaste persoon om te vra
4wd 24/7 is die kanaal wat hieride twee video opgelaai het. Hulle hou bietjie van goed dramatiseer en is deesdae meer 'n advertensie vir produkte, maar hulle kry die boodskap in 'n opwindende manier deur. Daar is duisende meer aktuele video's oor diesel swaps, maar hieride is redelik relevant.
Eerste video:
Tweede video:
Water Peter sê is reg, jy gaan bitter baie betaal en definitief voordele trek, maar uit 'n finansiële oogpunt uit is dit baie moeilik om gelyk te trek. Baie slimmer om net 'n diesel voertuig te koop in die eerste plek...
Behalwe as ons praat van M57 swaps dan worry ons nie oor koste implikasies nie[emoji16]
Sent from my SM-S901E using Tapatalk
