Electronic Ignition on L28?
pietpetoors
Junior Member
Junior Member
Full Name: Pieter Pretorius
Nickname: pietpetoors
Home Town: Langebaan
Current 4x4: Hilux 2.7
CJ 5 Jeep with Patrol Mechanics
Post by pietpetoors »
I want to change my 2.8 to electronic ignition.
I see on this one web site is coils and an ignition module for a Skyline.
Is this something one would be able to use for it?
Would one still need a management system as well?
I like the idea of a coil on each plug but then again I prefer keep things as simple as possible.
Link to module:
http://www.onlinecarparts.co.za/en/elec ... 6701-.html
Link to coils
http://www.onlinecarparts.co.za/en/elec ... 83-86.html
Re: Electronic Ignition on L28?
Daar is n module wat jy binne sit en dan vervang dit die punte en kondenser Piet Connan het dit gebruik hy kan jou meer daarvan vertel
Has thanked: 1136 times
Been thanked: 1047 times
Contact Bruce at Offshore Marine in Cape Town, tel:(021) 786-1007
He sells an Igniter electronic ignition module which basically just replaces the points. It's under R2k, and works like a bomb.
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Post by mvcoller »
Hierdie ouens doen honderde sulke conversions. Het my resies Alfas en ook my Safari gedoen. Nooit probleme opgetel nie
https://www.cylex.net.za/company/distri ... 65343.html
Die VG30 [V6 3.0 Haqrd Body se dizzy werk as jy electronic wil gaan .. D21 Nissan se VG30 engine s'n
MAAR dan weer, LOBO loop F I en beheer met Diktator [Arries het nou di S PITRONICS ecu uitsorteer - so as jy wil F I gaan [eeeendag] het jy E C U opsie [280Z Datsun/ Nissan asook die 2,8 GTX se fouel injections pas op faai enjin.
Ek droom nog op LOBO te Turbo .. so , T3 of T4 behoort my gouer annerkant te kry ?
[LOBO drop nog n Golf van robot tot Robot]
