BullBar..Is it really necessary for Overlanding
ra_01
Full Name: Rahul
Nickname: Rahul
Current 4x4: Patrol 4.8 2016
Has thanked: 23 times
Been thanked: 60 times
Post by ra_01 »
Hello All,
As sub says; do I really need to replace the standard with a steel bullbar (ARB/TJM etc.). Car already has a descent approach/departure angle. I am trying to keep the vehicle as standard as possible and avoid any complications that may occur due to loading up of vehicle with these accessories.
BB's are heavy (may be over 70kg's), this add's up a lot of weight in the front. Which means I may have to upgrade the suspension as well.
I am not into 4X4 sports. So I will only using my Patrol for overloading purposes (Traveling in Africa).
Thanks in advance.
Rahul
Current Straight 6 :wink:
SCUBA Patrol
Full Name: Phillip Jacobs
Nickname: Phillip
Has thanked: 31 times
Been thanked: 32 times
Re: BullBar..Is it really necessary for Overlanding
Post by SCUBA Patrol »
Rahul,
No need for a aftermarket bulbar, but dit does have some advantages.
    it does provide you with high-lift jacking points at the front of your vehicle,
      and a more solid platform for the mounting of a winch.
      to name two that is major form me when doing over-landing.
      Also it does make your patrol look more intimidating!
      Phillip
      2006 3l with MADMAN
      Stefan
      Full Name: Stefan de Villiers
      Nickname: Stefan
      Post by Stefan »
      As Philip said, there is no need to fit a replacement bumper/bull bar. There are people that can even fit a winch behind the standard bumper, if I'm not mistaken.
      It's your Patrol, you do with it as you please. :biggrin:
      graham1
      Full Name: graham robertson
      Nickname: graham1
      Home Town: Harties
      Has thanked: 9 times
      Been thanked: 100 times
      Post by graham1 »
      Of course it is. What do you put your beer on otherwise while enjoying the view at the top of a hill? :biggrin:
      Its probably not necessary, but, we had an issue with a taxi the other day on the open road, which could very well have left us stranded on the side of the road if were not for the bullbar. The bullbar took a hell of a hit!
      Imagine that happens 2000kms from home without a bullbar?
      I guess, like all things, its a nice to have. Probably not necessary though.
      ra_01
      Full Name: Rahul
      Nickname: Rahul
      Post by ra_01 »
      SCUBA Patrol wrote: 13 Mar 2018 09:00
      True dat
      Rahul
      Oetie
      Full Name: Leon Fouche
      Nickname: Oetie
      Has thanked: 394 times
      Been thanked: 141 times
      Post by Oetie »
      For over landing I would think a bull bar is necessary from a safety point of view, ie unexpected meetings with taxi's, cattle etc.
      Also for the reasons already mentioned re lifting points.
      I have seen on a forum where a road traveled, I think it was on Hunters Road in Botswana, was so muddy that they went through the veld next to the road, with smallish trees and bushes in the way. The vehicles with bull bars easily pushed the trees/bushes over, something I would struggle to do without a bull bar....
      In the end it comes down to preference and I would prefer to have one.
      ORRA - L65
      HAM - ZS6LEF
      Tlou - 2009 Patrol TD42T
      ra_01
      Full Name: Rahul
      Nickname: Rahul
      Post by ra_01 »
      Stefan wrote: 13 Mar 2018 09:12 There are people that can even fit a winch behind the standard bumper, if I'm not mistaken.
      Thanks Stephan..Will keep this in mind.
      Rahul
      ra_01 wrote: 13 Mar 2018 10:16
      Before I fitted the BZT front bumper, I had a winch behind the standard bumper, with a winch plate. I'm not sure where the winch plate is now...
      I think I gave it to David with the plan to have it reverse engineered by Mr Connan. But that was loong ago... Anyways, there are probably a few floating around somewhere...
      Been thanked: 273 times
      If weight is your biggest concern, then if I remember correctly one of our Cape members had an Alu bulbar fitted. Better than standard and lighter than steel bull bar...
      The steel bar protect your cooling system and your lights two things you cant come home without ...if you hit a donkey or a warthog or something with a bar you can make a plan getting radiators ect in the bush is a problem
