Spare Wheel Cover
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Spare Wheel Cover
Post by Clem »
Morning guys,
I wonder if somebody can point me in the right direction? I have a 4.8 GRX GU. It came from the factory with the large silver grey plastic cover over the spare wheel (the locking cover). The spare wheel also has its own independent locknut on it. I recently purchased one of those Thule bicycle racks which mounts on the tow bar. It seems to work very well with the "ugly Bosal" tow bar that bolts to the point where the recovery ring is normally located, especially if one drops the actual tow ball down to the lowest point. However, even when doing that, the plastic spare wheel cover gets in the way to a degree – it is difficult to operate the locking handle on the bicycle rack and also, the vertical frame presses up against the spare wheel cover. The cover itself is quite a bit larger than the wheel and I found that removing the cover solves all the problems. However, I would still like some sort of a relatively tight fitting canvas cover or similar for my spare wheel. What are my best options in this regard and where would I find it?
All input and advice much appreciated.
Cheers,
Clem
Rhett
Nickname: Rhett
Home Town: Heidelberg
Has thanked: 163 times
Been thanked: 78 times
Re: Spare Wheel Cover
Post by Rhett »
Clem, try Lobiz. They sell escape gear wheel covers:
http://lobiz4x4.co.za/
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
IanT
Full Name: Ian Temperley
2008 4.8 GRX Umkombe
Post by IanT »
Or my upholstery guy could make you one think it is about R300
Full Name: SJC
Has thanked: 237 times
Been thanked: 203 times
Clem
Nickname: Clem
Post by Clem »
Many thanks guys - some great links there!
Carel
Full Name: Carel Vos
Nickname: Carel
Home Town: Germiston
Current 4x4: 84 Safari
2001 Patrol 4.5 GRX
Been thanked: 10 times
Post by Carel »
Taunotent can also make you one (custom designed). They are next to the N12 between Germiston and Edenvale.
http://www.taunotent.co.za/contact/
Clem
Nickname: Clem
Post by Clem »
Thank you Carel. I did enquire but a plain black one with the word "PATROL" in silver lettering per the OEM one is a bit more than R1.5k - which seems a bit much for me. I think I may just order a plain generic black one off one of the other links for about R500. Probably makes more sense.
Been thanked: 473 times
Clem... .you need a rock band on that cover !!!..... You can't call it Led Zeppelin, cause If I ever get a grey 4.8, then that name is already registered to me......hahahaha. So you can have anything else.... :rolling: :rolling: :rolling:
"Jannie Vrot en die pomp rewolwers"
:yipes:
Clem
Nickname: Clem
Post by Clem »
Nee kerels - too exciting for me! 😁
