Intermittent water trap warning light 2000 Patrol
- Full Name: Elmar Henning
- Nickname: EFH
- Home Town: Bloemfontein
- Current 4x4: 2000 Nissan Patrol 4.2 Turbo Diesel
- Home Language: Afrikaans / English
- Has thanked: 6 times
- Been thanked: 12 times
Morning all, I seem to have an intermittent error on my 2000 Patrol's water trap warning light, seems that it is not making proper contact. It randomly flickers, switching on and off. I have drained the trap and only diesel comes out. Is it a replaceable part or maybe a fried connector somewhere? Anyone have a similar issue?
2000 Nissan Patrol 4.2 Turbo Diesel GL
Burnco Replacement Bumper, Suspension Lift, Terrain Taimer 'erd
Turbo Conversion by Sojo Automotive - Michael Steyn
- Full Name: SJC
- Has thanked: 237 times
- Been thanked: 203 times
Re: Intermittent water trap warning light 2000 Patrol
How old is the diesel filter?
- Nickname: EFH
Bought over December, car was recently serviced - 2000 +- km ago.
- Full Name: Ian Temperley
- Been thanked: 92 times
Maybe you pumped in some dodgy diesel, I would replace the filter first before you go looking for other things, from memory they are about R280
- Nickname: EFH
Easy enough to do, I'll start there - thanks!
- Been thanked: 473 times
Micheal gave me some advice the other day when I was at his place. Apparently there is an "O" ring that may be missing on the filter housing. If this is a reason for your flickering light, I honestly have no clue, but this "O" ring would fit between the top of the filter that screws into the housing and the housing itself. I assume, as i haven't done mine yet, that this "O"ring fits into the housing than onto the filter. This "O" ring is not the big one on the filter itself that you spread a bit of oil onto when fitting a new filter.
Maybe its missing and is causing something to cause something to cause something to flicker..... just my stupid 2 cents worth
Water trap alarm on 2000 Patrol 4,2 ??? Waaaaaar sit daai dêng? iNyathi hetti sulke goeters nie ???
Oom, have a look at the bottom of your diesel filter. There is a thingy screwed onto the bottom of the filter. That thingy has a thin wire that has a connector on that clips into the wiring harness that tells the little liggie on your dash that tells you that you have poeffie in your filter. It's probably the most advanced electronics on a TD42 motor like ours......hahahaha
There is a float inside the filter that screws off and can be moved between filters when there is water it floats and switch makes contact ...check your filter for water then unplug and then see if problem is still there ...if is gone have alook at switch or replace
Yah, that bottle thingy is there. I sometimes drain it for the heck of it .. BUT I have never seen a 'liggie' OR a wire coming from that botteltjie thingyricster wrote: ↑29 Jan 2018 17:02 Oom, have a look at the bottom of your diesel filter. There is a thingy screwed onto the bottom of the filter. That thingy has a thin wire that has a connector on that clips into the wiring harness that tells the little liggie on your dash that tells you that you have poeffie in your filter. It's probably the most advanced electronics on a TD42 motor like ours......hahahaha
