Trouble shifting from 4Hi to 2Hi
DirkErasmus
Full Name: Dirk Erasmus
Nickname: Dirk
Current 4x4: 2005 Patrol 4.8 GL
Has thanked: 46 times
Post by DirkErasmus »
I sometimes have trouble getting out of 4WD to 2WD with my 2005 Patrol 4.8 GL (P63).
The 4x4 light remains on, and I can feel all 4 wheels engaged, even though the gear is in the 2Hi position.
I have tried reversing (about 40 meters), drove about a kilometer to the shop, but still nothing.
The previous time this happened 4x4 disengaged on its own (and the 4x4 light went off) after driving a few kilometers at low speed (<80km/h).
Have any of you guys had this issue too?
And any advice on what I can do or am doing wrong? :helpsign:
Re: Trouble shifting from 4Hi to 2Hi
Mabe shift no neutral let the clutch out and then reverse ? Mine comes out as soon as i reverse
Over time I had various of my 4x4's doing that. I find on my Patrol if I manual lock the hubs it goes out of 4H immediately. BUT with the hubs on Auto I have the same problem. One of the causes I found was if the front wheels are not dead straight and also if the vehicle is not level. But with the hubs on lock it has never happened to me [yet]
Dirk, is yours is the auto 4.8?
I have also had mine stay in 4x4 for a good few meters at times. I thought it was just due to the diff "wind-up", but always disengages back to 2x4 after I either wiggle the stering left and right for a few meters while going forward and/or backwards.
It's weird that yours stays on for so long though. Thats not normal. I'm sure others with 4.8 autos will have better advice than me though
ricster wrote: 26 Jan 2018 12:27 Dirk, is yours is the auto 4.8?
Me thinks Dirk drives Grant's old Patrol which is a 4,2 Diesel GQ mos ??
4.8 gl thats manual
Kagiso II wrote: 26 Jan 2018 12:38
Oom Mac... Dirk who started this thread is a different Dirk to the one you are thinking of
Tinus lotz wrote: 26 Jan 2018 12:44
4.8 gl thats manual
I drove this Patrol a while back ( he stays around the corner from me).... for some reason I'm sure its an auto, but may be wrong
Rhett
Nickname: Rhett
Home Town: Heidelberg
Has thanked: 163 times
Been thanked: 78 times
Post by Rhett »
Mine also disengages pretty quickly. Usually I drive in an "S" pattern to disengage quicker
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
I need to check the drivers manual ( will light stay one when..) but my common sense tells me that if the Patrol 4wd light should be switched purely by the position of the gear selection lever - similar to a reverse light, the 4wd / 2wd is nothing more than a shift between 2 gears in a manual gearbox say 2-3. This is as mechanical/hard shifting gears with muscle power as it comes, there is no electronics, solenoids , valves or hydraulic actuators involved that might be trying to get back into 2wd . it's on or off .
The only reason it can stay on
shifting mechanism feels like it is in 2wd but actually still in 4wd
sticky switch?
When shifting from 4Hi to 2Hi on the move will generally keep the front diff turning until the auto hubs disengage - normally by moving in a different direction from the locking action (i.e. reverse )
