Re-new-it Ball joints and steering rods
- TIMKEN
- Full Name: NICO LINTVELT
- Nickname: NICO
- Home Town: THABAZIMBI
- Current 4x4: NISSAN PATROL 4.8
NISSAN SAFARI DOUBLE CAB - Home Language: AFRIKAANS
- Has thanked: 13 times
- Been thanked: 11 times
I am bussy with a Safari rebuild and want to overhaul the complete steering. No luck for new ones at our local spares shop. Any idea where to found new parts or do anybody have experience whith re new it refurbishment. What i can understand is that they pump in some sort of polymer that take up the wear.
Please advice and if it is worth it who do you recoment?
Re: Re-new-it Ball joints and steering rods
- Been thanked: 1036 times
Nico, ek het daai al twee keer probeer.
Op ball joints wat net draai en nie op en af beweeg nie, en ook nie veel stampe kry nie, kan dit amper die moeite werd wees.
Maar op my Patrol se "drag link" het dit minder as 3000km gehou.
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
I got a fairly good second hand steering box lying aroundTIMKEN wrote: ↑22 Jan 2018 18:34 I am bussy with a Safari rebuild and want to overhaul the complete steering. No luck for new ones at our local spares shop. Any idea where to found new parts or do anybody have experience whith re new it refurbishment. What i can understand is that they pump in some sort of polymer that take up the wear.
- Nickname: Wilkie
Nee ek beveel dit glad nie aan nie...!!!!Peter Connan wrote: ↑23 Jan 2018 05:22 Nico, ek het daai al twee keer probeer.
- Nickname: Wilkie
twee kaste vloeibare verversings wat jou laat afkoel op n sommers dag
- davidvdm
- Full Name: David vd Merwe
- Nickname: David - Hillbilly
- Home Town: West Coast
- Has thanked: 4 times
- Been thanked: 48 times
Thread revive time...
Where do we get steering parts for a 1980-83 Safari bakkie. I have the C200 diff under the Sani, and my tie rod ball joints look bad. The rubbers are all perished, although I can't feel any play on the ball joints. But I am moving to a very sandy and dusty environment where I will be negotiating heavy sand daily. And need to replace these soonest.
Autozone and the usual suspects can't help me. Non of their catalogues go back that far, and I don't want to get into fabbing some special steering setup right now.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
- Seandp
- Full Name: Sean Du Plessis
- Nickname: Sean
- Current 4x4: Suzuki sj 410(toy)
Gu Patrol 4.2tdi GRX (Also on the smokers team now) - Home Language: Afrikaans
- Has thanked: 9 times
- Been thanked: 60 times
go to sids suspension parts they are in pta west if the have the make up new arms with newer style ball joints that is available other option is to bring stuff from Aus but that is costly
