Patrol 4.8 spark plugs
DanieG
Full Name: Danie Gerryts
Nickname: Danie
Home Town: Stilbaai
Current 4x4: 2013 Nissan Patrol 4.8 GRX A/T
2016 Ford Ranger 3.2TDCi 4x4 A/T Supercab
Has thanked: 37 times
Been thanked: 8 times
Post by DanieG »
The time had come for my first service of the Patrol. I understand that it is a major mission to replace the spark plugs, apparantly half the intake manifold has to be removed. If I replace the plugs, I might as well replace them with something which is going to last longer than the normal plugs. I have read that a good replacement is PLFR5A-11 from NGK. In the spark plug manuals they say that it is suitable for the 4 liter Navara, but nothing about the Patrol. So, does the Navara and the Patrol use the same spark plug?
Danie Gerryts
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: Patrol 4.8 spark plugs
Post by JoshJ »
I do not know if they use the same plugs.
Service manual states plugs every 30 000km if I remembered correctly. I changed mine with the specified NGK plugs. It not such a heavy job. I did it in 4hrs and that was taking my time fiddling with everything else as well.
30000km is a long time. Reverts to once a year for most. :mytwocents:
Being alive is a Blessing!!
Joshua
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
If my memory serves me right the platinum plugs is rated fro 90k km and my service book states replace at 90k, unfortunately some dealers / service agents replace them with normal plugs that do not last as long. I found normal plugs,
The plug number is correct and you need to split the manifold to replace.
AndriesS
Full Name: Andries
Nickname: None
Post by AndriesS »
removed duplicate post
Has thanked: 246 times
Yes, for the TB48 use NGK PLFR5A-11 (Platinum = more $$$), or you can use the cheaper LFR5A-11.
http://patrol4x4.co.za/viewtopic.php?f=42&t=1640#p15127
http://patrol4x4.co.za/viewtopic.php?f=44&t=976#p9682
Users browsing this forum: Bing [Bot] and 4 guests
