Extreme Death wobble
Gihan
Full Name: Gihan Megannon
Nickname: Gihan
Home Town: Delareyville
Current 4x4: td 4.2 turbo charged nissan patrol.
Has thanked: 1 time
Post by Gihan »
Naand. My patrol het een verskriklike erge death wobble. Ek het al letterlik alles vervang wat ek an kan dink daar is om te vervang op die voor suspension. Ek gan die goed lys wat al vervang is.
Wiel Bearing Volledig met kingpins alles.
Tierods
Panhard bushes
Steering Damper
Steering Rod
Nuwe Coils
Stabilizer arm Bushes.
Ek het self al n ander stel rims en tyres opgesit en die wobble bly diesefde. IS daar dalk iemand wat weet waarnatoe ek die Trol kan vat om te laat kyk na asb. Ek bly in Delareyville Noord Wes maar kan hom Pta toe vat. Groete.
Has thanked: 61 times
Been thanked: 258 times
Re: Extreme Death wobble
Kontak vir Graham Cummings (Pathmaker op die Forum).
Hy bly in Valhalla.
As dit uitgesorteer kan word, sal hy.
083 vier-een-sewe, sewe, 5, nul, 3.
Hy is egter reeds Noordkus toe vir die naweek.
Jy sal hom Maandag in die hande kry.
Sterkte
Gihan
Nickname: Gihan
Has thanked: 1 time
Post by Gihan »
Baie dankie Alex sal met hom in kontak kom me hoor wat hy se.
Baie dankie.
I would definitively look into letting Graham sort it out for you, or alternatively, and this was what I did on my Patrol, check the KingPin Bearings. You can check it with a pull gauge to see how many Nm it takes to turn the front wheel left and right. Unfortunately I dont have one of those, so I just took the shim out on the top and bottom king pin bearings. This took maybe 10 mins per side. There are youtube videos that explain it perfectly. I followed the video and took mine for a drive afterwards and it was like driving a completely different car.
It would be best to replace the bearings and refit the shims, I still need to do this ( been too lazy actually to go get them and replace .... :lol: :lol: ) and that was many years back. I use my patrol every day as a daily driver too.
Another thing is the play on the steering wheel. I had a lot of play. I had it adjusted properly so that It still returns to straight after cornering and my Patrol rides 1000 times better.
Has thanked: 1130 times
Been thanked: 1044 times
Het jy al die agterste as se busse ge-check?
As jy die kingpin bearings vervang, is dit belangrik om die pre-load te meet soos Cedric gese het. Dit beteken egter dat mens die hele as moet oorbou, want die meting moet gedoen word sonder die side-shafts...
Has thanked: 243 times
Been thanked: 208 times
"Backyard Mechanic 02: How To Fix Nissan Patrol DEATH Wobbles!"
Ek het vir Gihan gehelp met klomp werk op sy voor aste.
Al twee kante se kingpins asook die wielbearings is nuwes wat ek ingesit het.
Nuwe panhard bushes
Nuwe castor correction bushes
Nuwe 2" coils (was n weird mod gewees op die voor as wat reg gemaak moes word)
Nuwe tierods voor en agter.
Daar is letterlik niks meer wat mens kan ruil op daai voor aste nie
Michael, have you tried to raise the back of the patrol up a little. Before I did the shim removal on mine I pumped the air lifters (bags) that I fitted to just the rear suspension which raised the back end of the patrol up a little. There was a definitive difference in the wobble I had. I assume it changes the geometry of the caster slightly and on mine was probably just enough to get it to as close to the sweet spot as I possibly could with just the air helpers.
I may be completely wrong with this, but when all other options are not working, then lets think outside the box. It could be that the rear coils are a soft ride and have possibly sagged a bit in comparison to the front. With the 2" lift, its almost on the cuff of needing castor correction bush, or if you already have the castor correction bush in, then maybe its then too much correction. I think with the standard bush on a 2 inch lift with a bit of a sag at the rear replicates something close to a 3" lift on the front suspension. By raising the rear the angle changes ever so slightly bringing it back to a 2" lift ( castor angle ).
As a test I would temporarily raise the rear by an inch with a spacer or something, and do a test run. If it works let me know.... if it doesn't ....let me know.... :lol: :lol:
What I can say is that it worked for my Patrol as I have and had a lot of stuff in the back.
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Has thanked: 182 times
Been thanked: 206 times
Post by Anthony Forgey »
Perhaps the steering box is buggered. Means the Pitman Arm will be loose.
Just a suggestion
Maybe the free play in the box must be adjusted
Again just a suggestion
Yeah I mentioned that too on my earlier post. Also makes a big difference, but doesn't 100% resolve the problem, more just solved the action of the wobble and not the wobble itself.
I used to hate getting to about 80Km/h odd and then hold the steering with white knuckles waiting for the wobble, then it calmed down at about 115Km/h, but came back just after 120km/h..... now its a sweet smooth ride in the Iron Maiden
