Wiring through Firewall (GU Y61)
- JohnBoyZA
- Site Admin
- Full Name: John Murray
- Nickname: John Boy
- Home Town: Bloubergstrand
- Current 4x4: Patrol GRX 4.8
- Has thanked: 1046 times
- Been thanked: 231 times
Hi Guys
anyone done wiring through the firewall recently? I need a LED bar switch and USB socket wires to go through to the center console from the battery.
What's the best path?
Thanx
John
Thanx
John
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 451 times
- Been thanked: 724 times
Re: Wiring through Firewall (GU Y61)
John,JohnBoyZA wrote:Hi Guys
Thanx
John
There are two rubber bungs through the firewall that I am aware of. This is on the 4.5.
The first one, is difficult to get to. It's near the centre of the vehicle, just behind the motor. I'd also suggest not using that one, as that is also where the main ECU harness enters the cab.
The second one is on the driver's side more-or-less directly under the brake booster. It will come out more-or-less at the driver's right hand knee. That one is unused (on my vehicle at least), so it's relatively easy to get access to it, and take wires through it without the potential of damaging any standard harnesses.
Hope it helps.
I used a rubber grommet near the steering colum on the firewall.
It sounds like the 2nd one Ian is referring to.
- iandvl
- Nickname: Ian
Yes. That is the same one.hugejp wrote:I used a rubber grommet near the steering colum on the firewall.
it was still a tight squeeze, but it worked...
- Been thanked: 473 times
Yes, well..... moving swiftly along.....hugejp wrote:it was still a tight squeeze, but it worked...
Cedric!
What can I say, I Love my Patrol.
You dog... I know where you live & work china!
- JohnBoyZA
- Site Admin
Thanx Guys, will give you feedback when done!
What can I say JohnBoy.... I'm a special boy...haha
