Key in ignition chime
- DanieG
- Full Name: Danie Gerryts
- Nickname: Danie
- Home Town: Stilbaai
- Current 4x4: 2013 Nissan Patrol 4.8 GRX A/T
2016 Ford Ranger 3.2TDCi 4x4 A/T Supercab - Home Language: Afrikaans
- Has thanked: 37 times
- Been thanked: 8 times
I think it has been discussed before, but I am unable to find it. How does one stop the irritating chime when you open the driver's door with the key in the ignition?
Danie Gerryts
- AdrianPowrie
- Full Name: Adrian Powrie
- Nickname: AdrianPowrie
- Home Town: Alberton/Johannesburg
- Current 4x4: 2003 4.8 auto
Nissan 3.0 SE 2x4
Willy's Jeep/toyota... - Home Language: English
- Has thanked: 20 times
- Been thanked: 13 times
Re: Key in ignition chime
Umm, Take the key out before you open the door?
Just joking...
Must be one of the most irritating noises known to man...
Just joking...
Adrian
2003 4.8
Front bashplate (PC)
Transfer case skid plate (PC)
Adrian
2003 4.8
- Full Name: Fanus
- Has thanked: 244 times
- Been thanked: 219 times
Underneath the steering wheel (remove the "cover"), there is a apparently a brown plug with 2 red wires ..... unplug it...
Dwergie's Jimny Zook also has that .. it is there for SWAMBO people AND the new age yuppy type mannetjies
I was considering to just undo the switch in the door frame that activates when you open the door .. the roof light I can mos switch on and off myself .. BUT then the alarm is also de activated ..
THANX for the advice of teh switch in the steering colomn .. hope the Zook has the same
- DanieG
- Nickname: Danie
Are you sure, I do not want to 'unplug' the whole car, I do not trust all the electronics on the newer cars. I once towed a small trailer and when I switched on the headlights, the car went into limp mode. Turned out the wiring on the trailer was not standard.SJC wrote:Underneath the steering wheel (remove the "cover"), there is a apparently a brown plug with 2 red wires ..... unplug it...
Danie Gerryts
Just do it just a plug to the chime thingyDanieG wrote:Are you sure, I do not want to 'unplug' the whole car, I do not trust all the electronics on the newer cars. I once towed a small trailer and when I switched on the headlights, the car went into limp mode. Turned out the wiring on the trailer was not standard.SJC wrote:Underneath the steering wheel (remove the "cover"), there is a apparently a brown plug with 2 red wires ..... unplug it...
- JoshJ
- Full Name: Joshua Joubert
- Nickname: Joshua
- Current 4x4: 2004 GL TD42
- Has thanked: 81 times
- Been thanked: 96 times
I have disconnected mine and took pics of it. I wil see if I can find it.
Its not dificult to ID the plug. It is a cable seperate from the rest and only has 2 wires.
Being alive is a Blessing!!
Joshua
Joshua
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
Guys ..if you take the steer wheel colum cover of you will see a little two pin plug from your ignition barrel...just unplug it and the buzzer is gone
it takes you max 5minutes and a dop and the irritation is gone..... and all you need is a star (Philips )screwdriver
- Full Name: Fanus
Ja 'n Jimny sin werk pressies dieselfde. Ek het die prosedure al op 'n jimny gedoen (het voorheen een besit).Kagiso II wrote:Dwergie's Jimny Zook also has that .. it is there for SWAMBO people AND the new age yuppy type mannetjies
http://www.4x4community.co.za/forum/sho ... -BEEP-BEEP!!!!!!!!!!!!!!
