4.1 H233 front & rear gear ratios...
Hi guys...
I am looking to change final ratios on my 4.8
From the factory she came with 3.5 ratios (auto model)
I would like to jump up to 4.1 & I have my heart set on original Nissan parts after alot of research
So to order these I need a VIN number for a GU patrol with h233 diffs running 4.1 ratios
Please may I ask one of you with a vehicle matching the spec I'm looking for to PM me your VIN
Thanks in advance
JP
Re: 4.1 H233 front & rear gear ratios...
Any 4,2 Diesel Y61 Wagon will have that .. [like mine]
Can I trust you with my VIN number ? :think: :think: :think: :naughty: :naughty: :naughty: :lol: :lol: :lol: :lol: :lol:
O K .. Tjek your P/M :oldtimer: :biggrin:
Dankie Oom Mac!
Is daar enige rede hoekom die nie sal pas nie??
Solank hulle alby die h233 diffs het??
Opinions asb...
Full Name: SJC
Has thanked: 237 times
Been thanked: 203 times
Het jy dit al by Ni$$an geprys? Dit gaan miskien die selfde kos as 'n tweedehandse patrol met 4.1 ratio diffs... :rolling:
Ons sal sien... :pray:
1) Ek is ondsr die indruk alle 4.8's het H260's agter. Is jy seker jy soek die regte goed?
2) Kan jy nie 'n stel 4.5 aste by David koop nie?
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
SJC wrote:Het jy dit al by Ni$$an geprys? Dit gaan miskien die selfde kos as 'n tweedehandse patrol met 4.1 ratio diffs... :rolling:
Hahaha...R12800.00 per axle.....and that's just the crown wheel and pinion
Peter Connan wrote:1) Ek is ondsr die indruk alle 4.8's het H260's agter. Is jy seker jy soek die regte goed?
1) net die handrat 4.8 het die H260
2) die 4.5 se handbriek, propshaft en kleiner discs maak baie werk.
Full Name: SJC
They talk about a "compliance plate" which specifies which diffs are in the patrol.
Where is this plate situated?
The plate in the engine bay does not help much (on my GU)... :think:
"Please check you compliance plate - example below
HG41 = 4.11:1 - H233 Front & Rear
HH41 = 4.11:1 - H233 Front & H260 Rear "
http://www.marks4wd.com/diff-ratio-information
