Tyres too big?
biggles
Full Name: Steven
Nickname: Steve
Home Town: Durbanville
Current 4x4: GUII Patrol 4.8
Has thanked: 21 times
Tyres too big?
Post by biggles »
Will 305 70 r 16 be too big for 4800 GUII with 2 inch lift?
I have Cooper SST that are left over from the old patrol. I have a set of steel 16s that I have been planning to mount them too since the dark ages. The steelies are Russ's old ones so came of a pick-up.
Will they fit without a body lift?
:layrubber:
Re: Tyres too big?
Dont know what the offset is but those are actually just 33 so no problem even with no lift :salute:
Full Name: SJC
Has thanked: 237 times
Been thanked: 203 times
Re: Tyres too big?
if it is patrol pickup oem steelies, then they might be slightly narrow for 305's.
Patrol pickup steelies are 6.5jj with a very "close to body of car" offset... I got a set on my 4.5 with 255/85r16 tyres (also 33" but narrower). Had to fit 30mm spacers to prevent the wheels rubbing the inside of the wheel arches when flexing. My 4.5 got 3" lift (afaik)...
But if it is aftermarket steelies such as a-line etc. then it might be 7.5 or 8j with 00 offset. Which will prevent the rubbing.
biggles
Full Name: Steven
Nickname: Steve
Re: Tyres too big?
Post by biggles »
Went through my comms with Russ when I bought them. They are "Trailduster" / " Pro- White" 7j with unknown but suspect 0 offset.
I guess I will just fit one and compare to the current rims!! I have 6mm spacers.
Will the "fat" profile fit in? It is a a 33inch x 12 inch profile that is wider than the 'recommended" I can find on this site at least. And the uncertainty is due to them coming off a body lifted patrol.
:layrubber:
Re: Tyres too big?
Michael had 305 70 16 on his 4.2 Ian's dad has them now on standard patrol steelies ...you have the tires and the rims fit them and let us know...just check the center holes on the rims if you remove the spacers but you know that story by now :salute:
biggles
Full Name: Steven
Nickname: Steve
Re: Tyres too big?
Post by biggles »
Tinus lotz wrote:Michael had 305 70 16 on his 4.2 Ian's dad has them now on standard patrol steelies ...you have the tires and the rims fit them and let us know...just check the center holes on the rims if you remove the spacers but you know that story by now :salute:
Cool:)
:layrubber:
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: Tyres too big?
Post by JoshJ »
Ek soek ok 305/70/16. Volgende ronte
Being alive is a Blessing!!
Joshua
Been thanked: 430 times
Re: Tyres too big?
Steven, yes I had 305/70/16 BF Muds and had no problem whatsoever with them. I had a slight rub under flex on the inside of the body, but never heard it or felt it and this also happens with the 285/75/16 tyres so no drama :thumbup:
Been thanked: 473 times
Re: Tyres too big?
Will 16" rims fit on a 4.8??? I thought the calipers got in the way :think: :think: :think:
Re: Tyres too big?
ricster wrote:Will 16" rims fit on a 4.8??? I thought the calipers got in the way :think: :think: :think:
Jip i have original 4.8 16 mags the ones from 2003 2004 on my 4.8 same as the wheels on alex lexus
Return to “14. Rims & Tyres”
