Diff-lock Trouble
- Full Name: Richard Poalses
- Nickname: RTP
- Home Town: Boksburg
- Current 4x4: Patrol 4.8
- Has thanked: 7 times
- Been thanked: 1 time
Diff-lock Trouble
Hi Guys
I am sure this has been asked before but here goes .
If I try engage diff-lock when in 4L as normal it takes a few meter to engage and the light burns solid , but after a few meter the light starts flashing again and if you turn sharp you can tell the diff-lock has disengaged .
Any Ideas ?
Any Ideas ?
RTP
RTP
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 451 times
- Been thanked: 724 times
Re: Diff-lock Trouble
IIRC, the Patrol diff is vacuum actuated. This behaviour would lead me to believe you may have a leak in one of the vacuum pipes. Not sure how you test that though.RTP wrote:Hi Guys
Any Ideas ?
- Been thanked: 473 times
Yip, I think Ian is correct. trace those vacuum rubber hoses from under the bonnet to the diff. Maybe there is a tiny leak, resulting in the diff lock dis-engaging after a short while.
- iandvl
- Nickname: Ian
Good luck.
And please post your methodologies / findings here for reference.
- Nickname: RTP
Hi Ian
If I have it correct i can swap the pipes at the back by the diff as the other pipe line have vacuum all the time if the diff-lock kicks in and stays in we know we have a leak in the line .
RTP
RTP
- johanp
- Full Name: Johan Pheiffer
- Nickname: Johan
- Current 4x4: 2004 Patrol 4800 GRX
- Has thanked: 1 time
- Been thanked: 26 times
Hi Richard
When the difflock is off, one pipe will have vacuum. When you switch it on, the other pipe will have vacuum.
If you swap the pipes, you will have to switch the difflock off and then it should engage.
When I had problems with mine I swapped the pipes at the solenoids in the engine bay to test.
My problem was caused by one of the solenoids.
- Nickname: RTP
Hi Guys
To follow up on the Diff-Lock story. After changing the pipe round in any way way I try I always get the same re-salt .
The Diff-Lock engages after a few meters then if you turn left you can see the inside wheel is lock. But if you turn right the Diff-Lock disengages .
I am worried it may be the gear it self that is worn . does anyone have experience with this?
RTP
RTP
- Been thanked: 1036 times
Not personally but I have heard of cases where the machanicals have broken.
However, there would usually be a loud clacking sound when turning if the mechanics are damaged. I also wouldn't expect there to be any difference in behaviour between a left and a right-hand turn.
- Rhett
- Nickname: Rhett
- Home Town: Heidelberg
- Has thanked: 163 times
- Been thanked: 78 times
So, not a nice way to revive a post but what choice do I have.
Just tested my diff-lock now again as I haven't used it since Thaba Nkwe.
After engaging the diff-lock in a stationary position, I slowly pull off and snake left and right. Weirdest thing then begins happening. turning right it engages, then when turning back to the left it disengages. As soon as I turn right again is engages. (I am only using the diff-lock light on the dash as an indicator that it is engaging / disengaging)
I want to take it back out a bit later to a bit more open ground where I can see if the inner wheels are digging up grass if I do circles. At this point I am slightly concerned as the river trip is coming up and I'm not happy taking it out if there is a mechanical issue.
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
