Hello guys
Has anyone bought / played around with a ScanGauge II? I know the older model is not compatible but I have seen it more and more on the Toyota 4x4's.
https://www.scangauge.com/products/scangauge-ii/
Looks to be around R 2500 with shipping.
ScanGauge II
- Rhett
- Nickname: Rhett
- Home Town: Heidelberg
- Has thanked: 163 times
- Been thanked: 78 times
ScanGauge II
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
Re: ScanGauge II
I would like to know if it'll see our 2004 4.8 models???
Re: ScanGauge II
I sent them an email, but no response as yet...
- Rhett
- Nickname: Rhett
Re: ScanGauge II
Thanks JP, I have checked on the Aussie patrol forum and it looks to be a bit of an issue with 4.8 patrols. Check this compatibility list:
http://scangauge.com.au/compatibility-nissan/
It says not compatible for Y61 models. Hopefully they have come up with a solution, hope they reply to you!
Rhett
- Full Name: Jacques Steyn
- Nickname: AceVentura
- Home Town: Durbanville
- Current 4x4: '08 Nissan Patrol 4.8 GRX
'96 Ssangyong Musso 602EL TD Executive - Home Language: Afrikaans
- Has thanked: 3 times
- Been thanked: 7 times
Re: ScanGauge II
Any one using a modern Scanguage on a 4.8 GRX?
The website only states : compatible with Nissan Patrol 2007 Onwards
When nature calls
Jacques Steyn
2008 Nissan Patrol 4.8 GRX A/T (190kw)
Tough Dog Suspension | Outback Extreme Rear Replacement Bumper | Ironman Front Bumper
Air Helpers | Snorkel | Frontrunner Roofrack
Wishlist: TPM, Seat covers, drawer system
Jacques Steyn
- Mamba
- Full Name: Anton Schutte
- Nickname: Anton
- Current 4x4: Patrol 4.8 GRX
- Been thanked: 12 times
Re: ScanGauge II
I use "Car diagnostics Pro" on my Phone connected to a Bluetooth OBD2 dongle plugged into a 2004 4.8GRX pre face-lift
Re: ScanGauge II
Thanks. What info are you getting back from the ECU? The OBD2 scanner i bought from ebay did not work on the Patrol or my Polo - it was a cheap unit, so I think the unit is crap.
Got a reply from scanguage, so I'm thinking about going that route
Hi Jacques,
Yes ScanGauge2 works well with your 2008 Patrol.
Have a nice day and please let us know if you require further assistance.
Kind Regards,
Boris / Support
ScanGauge Australia
Like us on www.facebook.com/ScanGaugeAustralia
Hi Jacques,
Kind Regards,
Boris / Support
ScanGauge Australia
When nature calls
Jacques Steyn
Jacques Steyn
- Mamba
- Nickname: Anton
Re: ScanGauge II
I can see items such as coolant temp, timing, battery voltage and lots more. I can adjust timing, idling and read/ reset fault codes.
