seatbelt rewind
seatbelt rewind
Howzit guys,
I'm sure a few of us especially with older Patrols have noticed the lack of pull on the rewind of your seabelts??? Drivers belt especially...
My vehicle is a 2004 & the drivers seatbelt is taking a bit longer to retract that I remember when I first got her.
Are there any fixes for this or is this a trip to the scrapyard for a newer unit?? & is this an easy job?
Can the clever okes please chime in here...
J
J
- Full Name: SJC
- Has thanked: 237 times
- Been thanked: 203 times
Re: seatbelt rewind
Mine is the same on the 4.5. Have to manually "feed" the belt to make it retract.....(2000 model).
Re: seatbelt rewind
So...
After a few mins on Google it seems alot of this issue is caused by nasty body oils, dirt & all the general k*k from our hands getting into the webbing.
This makes the belt more stiff & it struggles to bend through the guide, making it retract slowly.
There are a few tuts on how to scrub & clean the belt to make it supple again.
Seems to solve it most times.
Re: seatbelt rewind
Re: seatbelt rewind
I think I found the way I want to do this...
- Been thanked: 430 times
Re: seatbelt rewind
Nice find JP.....will be cleaning mine soon as mine also has the same problem.
Im just wondering if this is the actual cause of the seatbelt retraction problem?
Re: seatbelt rewind
Laat ons maar almal proebeer en sien, tenmunste het ons dan skooner Patrols!?
- Full Name: Jaap Steenkamp
- Nickname: Ds J
- Home Town: Stella
- Current 4x4: 1985 Hilux 4x4
- Has thanked: 1 time
- Been thanked: 7 times
Re: seatbelt rewind
Het iemand dalk probeer om die opwenmeganisme 'n slag behoorlik skoon te maak en te olie? Ek was al verbaas wat 'n bietjie olie of ghries kan verrig.
Ons sukkel ook met trae belde en ek gaan dit heel eerste probeer.
Re: seatbelt rewind
I agree that the mech may need to be cleaned of fluff & dirt, but oiling & greasing??? I'd be worried about grease getting onto the belt itself so I would proceed carefully with that approach... IMHO
- ChristoSlang
- Nickname: ChristoSlang
- Home Town: Pretoria, ZA
- Has thanked: 27 times
- Been thanked: 136 times
Re: seatbelt rewind
Good write-up here.
I've done the rewinding bit on a previous car - it takes a lot of focus and preferably extra set of hands...
