3 door GQ for sale on OLX
bruce_k
Full Name: Bruce Killerby
Nickname: Killa
Home Town: Cape Town
Has thanked: 38 times
Been thanked: 20 times
Post by bruce_k »
This is a rare beast in South Africa
https://www.olx.co.za/ad/nissan-patrol- ... cf0e5615b6
It's not mine, but I'm posting it here as someone might want to snatch it up...
Every dog has his day!
2006 Patrol TD42T GL
Re: 3 door GQ for sale on OLX
Alex .....you have to buy this one :surprised: :surprised:
Hy gaan nie lank staan vir daai prys nie
Home Town: Randburg
Has thanked: 198 times
Been thanked: 280 times
Kyk mooi vir scam, selfde ouens wat GU 1980 model adverteer vir R89k........... of nie :confused:
Sien die nommers is nie meer dieselfde, of ek het gister boom gerook.
Hy staan by - 37 albatross street Kempton park. Johannes 076 841 0217
Piet was daar hy wil hom deel van sy versaameling maak :blonde:
Home Town: Randburg
Dam - nice man :thumbup: :thumbup: :thumbup:
Ok Piet het eerste opsie op hom .....kom ons kyk wat gebeur hulle wag nog vir papiere ect tb42 met diff lock ...as ons te veel bel gaan hulle dink hy is gesog :lol:
Has thanked: 1141 times
Been thanked: 1049 times
Guys, after dreaming and thinking, i am afraid i simply can't afford it right now.
I have had a look and a short drive though.
The engine is a TB42 4.2l petrol engine with carburettor. 4wd and low range works, and there are no horrible noises underneath. Nor are there any signs of bumps and scrapes underneath. Suspension and exhaust appear to be standard. However:
Interior has been re-done, but not exceptionally well. The driver's door lining particulalrly is a bit of a mess. The interieo roor handle is not attached to the door itself.
The passenger window doesn't work.
The windscreen washer spray doesn't work.
The earial does not retract fully.
The diff lock solenoid only creates vacuum in one direction, and the tubes are buggered. I thus do'nt know if there is anything wrong with the diff itself.
The engine has a miss, and there are several oil leaks. I did not see any smoke though.
A couple of water hoses have been patched, and the overflow bottle is broken at the corners, although it still holds water.
The coil is the wrong size for it's bracket.
The oil pressure seems a little bit low at idle, and i felt the temperature climbed very quickly. I suspect it will get hot if asked to work hard.
There are several little dents and places where the clear coat is wearing through.
I would suggest a compression test to make sure the miss is not something serious, and the car will need some love before it could be relied upon, but i still would love to own it.
Ons tipping on the link in Post #1 it informs me that add is no longer available ..
bruce_k
Nickname: Killa
Post by bruce_k »
Kagiso II wrote:Ons tipping on the link in Post #1 it informs me that add is no longer available ..
There is a new link for some reason :doh:
https://www.olx.co.za/ad/nissan-patrol- ... d66f680881
