Difflock light not going off.
- Full Name: Abraham Johannes Du Plooy
- Nickname: A.J.
- Current 4x4: 4.8l Patrol GL
- Home Language: Afr
Hi guys
Ive got 2 problems.
1st my difflock light doesn't want to go off if I'm in 4x4 L and I switch it on the difflock itself switches on and off but the light is still on. Even if I'm in 2H its still on and flickering as a lose connection. I've looked at all my connections that I could find and sprayed them still light doesn't want to go off.
Please help???
2nd problem when I'm in 4x4lo and I turn sharp a loud GGGRRR noise come from my wheels what could that be and its only when I'm in 4x4?
I hope there is someone that can help me out there?!
Ive got 2 problems.
Please help???
4.8l GL Patrol
Re: Difflock light not going off.
The light problem is most likely in the switch on the rear diff. Some moisture get into the switch and then the pin on the switch get stuck. Just remove the switch from the diff, clean it so that the pin moves easely and that should sort the light out.
You could also have a problem on your vacuum pipes and solenoids for the difflock. If the pipes are leaking or are blocked then there is no return vacuum and your difflock stays on. (Hope that is not the case)
- Nickname: A.J.
My difflock does turn off its just light in the dash but Ill just check my pipes and make 100% sure.Wheels wrote:You could also have a problem on your vacuum pipes and solenoids for the difflock. If the pipes are leaking or are blocked then there is no return vacuum and your difflock stays on. (Hope that is not the case)
4.8l GL Patrol
- Nickname: A.J.
Dankie Herrie vir jou raad jou plan het gewerk ek het nounet klaar gemaak! Nou net vir my voorste wiele,ek het nou mooi geluister hule maak na al 2 kante toe klik klik klik as ek skerp draai net as ek in 4x4 is. Is daar iemand wat my kan help??
4.8l GL Patrol
- mike
- Newbie
- Full Name: M B Mulcahy
- Nickname: Mike
- Home Town: Somerset West
- Current 4x4: Land Rover Forward Control Series 11B
My guess is that the problem is caused by positive pressure in the diff housing, probably due to a blocked breather. This happens when the diff gets hot and the pressure build up compresses the actuator for the vacuum locking mechanism. I had exactly the same problem in the Messum Crater with my diff light flashing on and off and then staying on. I jacked up the one rear wheel to check if the diff was really locked and it was. I removed one back half shaft and drove to Uis but by the time I got there the problem was gone (due to the diff cooling down slightly). I eventually phoned someone at Gearmax who gave me the answer and as soon as I cleared my blocked axle breather the problem permanently disappeared.
Mike
Landrover Forward Control Series 11B
Nissan Patrol TD42 engine with Garrett GT35 turbo
Nissan Patrol 5 speed gearbox & Transfer Case
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
Mike, the vacuum actuator on the Patrol's diff is completely external to the diff, so I doubt that pressure build-up in the diff case could have actuated the diff lock as happened with your Gearmax diff.
- mike
- Newbie
- Nickname: Mike
Gerrit, I agree that if the actuator is external to the diff then my suggestion must be off the mark.
Mike
- Junior Member
- Full Name: Heimrich Swart
- Nickname: Swartjan
- Home Town: Evander
- Current 4x4: Mazda Drifter 2.5TD D/C 4x4 an hopefully a Patrol 3.0 td
Dieselfde ding het met my Mazda drifter gebeur, na n taamlike soektog was die diff nie die oorsaak van die geluid nie maar die transfer case. Dalk help dit?
