Dust leak around handbrake
hugh
Full Name: Hugh KENNEDY
Nickname: Hugh
Current 4x4: 2007 Patrol 3.0Di
Has thanked: 16 times
Post by hugh »
During my last trip to Botswana in my GU wagon, driving across Sua Pan there was a major dust storm coming out of the handbrake slot. I haven't investigated much yet, but any ideas if this is normal, or what the cause could be?
Re: Dust leak around handbrake
Under the leather gear-lever boot there is a second rubber boot.
I suspect it might be that that is split.
I would strongly recommend checking it out soonish, and if it is split, replace the gearbox oil, because if this is the case, some of that dust could have gotten into the gearbox as well.
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
Or if you had some work done (clutch replacement) the ARTISAN did not replace all the spares correctly..
hugh
Nickname: Hugh
Post by hugh »
Wilkie wrote:Or if you had some work done (clutch replacement) the ARTISAN did not replace all the spares correctly..
Thanks, but I haven't had any work done.
hugh
Nickname: Hugh
Post by hugh »
Peter Connan wrote:Under the leather gear-lever boot there is a second rubber boot.
Thanks, I thought it would be something like that, will check it out.
hugh
Nickname: Hugh
Post by hugh »
hugh wrote:During my last trip to Botswana in my GU wagon, driving across Sua Pan there was a major dust storm coming out of the handbrake slot. I haven't investigated much yet, but any ideas if this is normal, or what the cause could be?
I eventually took out the central storage compartment and found three large threaded holes through the floor (under where the rear ashtray is). No idea what these are for, but I plugged them and after the last trip through Moremi there was no dust from that area.
