Drag link/tie rod ball joints
- DH70
- Full Name: Donald Hastie
- Nickname: Donnie
- Home Town: Melkbos
- Current 4x4: NA
- Home Language: Afr, Eng
- Has thanked: 17 times
- Been thanked: 6 times
I need to replace the drag links removable ball joint and tried to fit TR5677 (tie rod ends), but they're too long. Anyone have a part number for the drag link ball joint? Luckily the fixed ball joint is still ok. I've added pics, but can only load a link on Flickr.
- Dustin
- Full Name: Dustin Roberts
- Nickname: Dustin
- Home Town: Port Elizabeth
- Has thanked: 42 times
- Been thanked: 59 times
Re: Drag link/tie rod ball joints
HI Donnie
You attach images by selecting the "Upload attachment" tab on the bottom.
Then you click "Choose file", browse the file you want to upload and then click "Add the file".
Once the file has loaded, hit "Submit"
- pic.jpg (773.78 KiB) Viewed 7001 times
a.k.a. Datsun Dustin
GO PATROL !!!
GO PATROL !!!
- DH70
- Nickname: Donnie
- Current 4x4: NA
Thanks Dustin.
- IMG_2784.JPG (3.47 MiB) Viewed 6983 times
- IMG_2819.JPG (2.73 MiB) Viewed 6983 times
- Zakhil
- Full Name: Zak Cronje
- Nickname: Zakhil
- Home Town: Gouritsmond
- Current 4x4: 1983 Datsun Safari
2003 Nissan Patrol 4.8 - Home Language: Afrikaans
- Has thanked: 25 times
- Been thanked: 7 times
Tinus lotz wrote:Piet makes complete new ones
Hi Tinus, het jy Piet se kontak besonderhede en sal hy vir 'n Safari kan maak?
- Full Name: SJC
- Has thanked: 237 times
- Been thanked: 203 times
Stuur hom sommer n PM:Zakhil wrote:Tinus lotz wrote:Piet makes complete new ones
Peter Connan op forum: http://patrol4x4.co.za/memberlist.php?m ... file&u=530
- Been thanked: 1036 times
Hello Zak.
Het nog nie vir 'n safari gemaak nie. Kan jy by my draai dat ek kan kyk hoe dit lyk?
Zero78 Vier56 398Nul.
Piet Piet Piiiiiiieeeeet !!!! Mnr Connan .. IF AS INDIEN ingeval jy wel vir SAFARI gaan mak .. LOBO het dringend nodig .. al sy rubbers is effe MURTU op die stadium
