Difflock not working
- Mamba
- Full Name: Anton Schutte
- Nickname: Anton
- Current 4x4: Patrol 4.8 GRX
- Been thanked: 12 times
Hi Everyone,
My difflock (2004 4.8 GRX) stopped working this weekend. When I engage the difflock the light comes on immediately. When I start driving I can hear a ratched sound coming from the rear diff, but the locker doesn't work. When the difflock is switched off the diff is quiet.
I jacked up the car last night and test the difflock. I connected the vacuum unit directly to the engine's vacuum to illuminate the valves etc. It still didn't work. The vacuum unit/ lights etc is working and does engage. I drained the oil, and found some metal parts stuck to the drain plug. Does anyone have some spare parts for this locker? Or any other suggestions?
Thanks,
Mamba
Thanks,
Mamba
- Dustin
- Full Name: Dustin Roberts
- Nickname: Dustin
- Home Town: Port Elizabeth
- Has thanked: 42 times
- Been thanked: 59 times
Re: Difflock not working
Just saw this put up on Gumtree.
https://www.gumtree.co.za/a-cars-bakkie ... 1010430809
Back end will be ok for spares.
a.k.a. Datsun Dustin
GO PATROL !!!
GO PATROL !!!
- Dustin
- Nickname: Dustin
You could always put in an Afroxlocker...weld the diff
Sorry, I couldn't help but put that out there
Hope you come right
Hope you come right
GO PATROL !!!
GO PATROL !!!
- Rhett
- Nickname: Rhett
- Home Town: Heidelberg
- Has thanked: 163 times
- Been thanked: 78 times
Hi Mamba
I would test the actuator on the diff. Maybe it's faulty and it's pushing the lock fork against the lock sleeve and making a noise? Not sure if it could even be that but worth a try.
Is the light flashing or does it stay fully burning?When I engage the difflock the light comes on immediately.
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
- Full Name: Clem Daniel
- Nickname: Clem
- Has thanked: 39 times
- Been thanked: 39 times
Mamba wrote:When I start driving I can hear a ratched sound coming from the rear diff, but the locker doesn't work.
Uh-oh. Doesn't sound good. How big are the metal bits?Mamba wrote:I drained the oil, and found some metal parts stuck to the drain plug.
- Full Name: HS
- Nickname: Picasso
- Current 4x4: Nissan Patrol
- Has thanked: 10 times
- Been thanked: 44 times
Postby Dustin » 22 Sep 2016 12:22
The problem with this option is that you have to buy a smashed car for 92k to get a second hand diff lock.
That makes even a new 28K ARB looker sound cheap.
- NMAD
- Full Name: noel
- Nickname: happy
- Home Town: C
- Current 4x4: 20
- Home Language: E
- Has thanked: 51 times
- Been thanked: 10 times
I would call David as he has a scrap 4.8 and I think its around a 2004/2005 model.Mamba wrote:Hi Everyone,
Thanks,
Mamba
- Been thanked: 1036 times
- Been thanked: 473 times
I have a feeling the dog clutch has kicked off its edges. Did you test it in reverse with the wheel up. If it holds when in reverse, but not in forward rotation, then I think the diff lock itself is cooked. If the light is showing solid, then the actuator is registering that the lock is fully engaged, so i doubt its the solenoid or actuator that is faulty.
