4.8 alternator
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
4.8 alternator
Post by AndriesS »
Friday I changed all the belts (Except the recent power steering belt). Also changed the AC tensioner bearing,
Did a quick trip to the Waterberg .
Then on Saturday afternoon on a cold startup had a bit of a racket, sounded like a belt slipping but goes away after about 5 seconds. same Sunday morning , think I woke up the valley.
Last night checked belt, all ok, noise is on startup and disappears after a couple of seconds, lot louder with bonnet open
Spray belts with soap - just to see if one disappears - no - do notice something funny .....
take power steering belt off, noise still there
slacken alternator, noise still there
remove alternator belt, pulley spins without noise .
refit belt - noise back
It's a challenge to start , get back to engine fast enough to put a stethoscope and listen - thus can't really isolate pump or alternator.
took the alternator to get it serviced
However when I sprayed the soap water, the alternator pulley steamed, and when I touch it after startup it feels hot, not scalding hot so I think it might be the bearing spinning?
I hope they find the fault, else there is 2 things left, visco fan and water pump.
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Re: 4.8 alternator
Post by Wilkie »
Andries how strong is your battery..?
what sometimes happen is your battery is getting old but has just enough power to start your car when cold and when the engines start the battery volts is down and the alternator picks it up and goes into full-charges mode
and your fan belt might just be a fraction to lose and hench the squelling noise
AndriesS
Full Name: Andries
Nickname: None
Re: 4.8 alternator
Post by AndriesS »
battery is 3 years old and starts very easy. I'll still check it though. Thx
johanp
Full Name: Johan Pheiffer
Nickname: Johan
Has thanked: 1 time
Been thanked: 26 times
Re: 4.8 alternator
Post by johanp »
I also recently replaced the belts on my Patrol and have the same noise when starting especially when it is cold outside.
I also replaced belts on my Ford bakkie and the belts screech at 2500rpm when it is cold outside.
Maybe the new belts are made from different material that causes this.
AndriesS
Full Name: Andries
Nickname: None
Re: 4.8 alternator
Post by AndriesS »
FYI
I took the alternator to the autolec and he said there is nothing wrong with it, I wanted to agree as it spins freely, no noise . He suggested I refit and check the pump, I nearly agreed but the only red light for me is the fact that the pulley became so hot so quickly.
End of the day I said just replace the bearings and lets check it . My screeching is gone, let's hope it stays that way.
PS , one less thing to worry about ; alternator uses normal pulley and not a clutch one, one less thing to give trouble after a muddy / dusty ride.
