Second battery tray
Gafas
Full Name: Pedro G Pereira
Nickname: Gafas
Home Town: Angola
Current 4x4: Patrol GL
Home Language: Portuguese
Has thanked: 27 times
Been thanked: 8 times
Second battery tray
Post by Gafas »
My Sunday DIY battery tray
cheers,
Pedro
Re: Second battery tray
Looks good man :salute:
Mine was attached in a similar way, and has torn the body in that area to bits.
Mine is now mounted directly to the chassis in three places.
Has thanked: 60 times
Been thanked: 255 times
The battery is heavy and persistent corrugated roads will do damage eventually, unless the mounting is really robust.
My first version of a battery bracket was bolted onto the body and 6 months later it started to tear.
The second version was still bolted onto the body but with plates welded to the body to strengthen it. So still not mounted to the chassis. I unfortunately do not have pictures and the battery is heavy to take out just for pictures.
It has lasted since (about 5 years). And that includes Kaokoland, which shook a lot of unexpected things loose in my car, but not the battery mounts.
Been thanked: 473 times
Everything mentioned above is exactly right. Mine also started to tear. The holes for the bolts onto the wheel well need to be reinforced to handle the vibrations !!!
One other thing. Om the TD42 motor your exhaust is sitting very close to the battery, and batteries don't like heat. On mine I have branches and a turbo so don't have the heat shield like you do, but even with the heat shield that battery will get hot. While you are busy with the tray, make 2 sides to the tray, one on the exhaust side and one on the side closest to the firewall. You can leave the front open to allow airflow from the front. This will make a HUGE difference.
Been thanked: 430 times
Thats a very neat job!! Well done :thumbup:
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Post by Stefan »
Looks good. :thumbup: :thumbup:
Mine also tore - reinforce the mounting!
Gafas
Nickname: Gafas
Home Town: Angola
Post by Gafas »
battery tray 2.0
First, thank you all for the feedback! Did the reinforcement today. Two more mounts and heat shield.
Nice ....what size battery can you fit there?
Gafas
Nickname: Gafas
Home Town: Angola
Post by Gafas »
75 amps, 18X28 cm
Return to “16. DIY Projects”
