Patrol a real donkey cart without powersteering
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
Driving into work today ( does not happen that often at the moment - the gautrain really works well) cruising at a decent speed I suddenly noticed the steering stiffening up just of centre, Not the greatest feeling when you are doing 120 :wink: Amazing how your minds work , left garage no wet patch so should not be oil loss unless sudden , radio - volume down, listen for new sounds, check tyre pressure gauge, all ok, keep eye on temp and alternator gauge.
Slow down a bit - too 100, take offramp to work and prepare for a gym section. Drove into parking slowly - you need man handle the beasty for the tight turns. (Steady speed you can handle the car quite easy but would not like to do an evasive maneuver .)
Pop the bonnet, belt is off. Luckily with the forum I can check what size belt and even what spanners I need ( I know I wrote that post) - even though I have a basic tool set I might as well buy a spare 12 and 14mm and get it going.
Re: Patrol a real donkey cart without powersteering
Did you have a spare in your car?
AndriesS
Full Name: Andries
Nickname: None
Post by AndriesS »
unfortunately not , but bought one and will fit in T time
Been thanked: 473 times
wow... did the belt jump off or break?
3 ton patrol and no power steering.....hahaha... I can only imagine trying to park at my local Checkers parking lot..... I'll look like Arnold Schwarzenegger by the end of it.... :rolling: :rolling: :rolling:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
interesting :think: :think:
how is the alternator belt ?
I lost all four fan belts the other day. I think one broke and got wrapped up in the others.
The only correct spares I had were the two for the fan/water pump/alternator. So I know exactly what you mean Andries!
