Injector Pump Leak
- Russ Kellermann
- Has thanked: 8 times
Injector Pump Leak
Hi guys,
I've just got back from a month long 8500km overland trip through namibia and botswana. No problems whatsoever.
Been back for 2 weeks and yesterday my injector pump seemed to start leaking . I noticed fuel on my front diff and traced it to the pump. Cant see where its coming from though.
What should i do?
Anyone know a reputable place in Cape Town to take it to. I cannot be without my vehicle for long. But, i think they will have to remove the pump, as i suspect they will need to replace the gaskets and seals.
Rather annoying.
Advice welcome.
What should i do?
Rather annoying.
Advice welcome.
Re: Injector Pump Leak
Russ it might just be a bolt or joke thats loose go see frans at his workshop and let him have alook before you do big things
- Russ Kellermann
Ja that was Cedrics advice too.
I must find out where his workshop is.
Good call.
Good call.
- davidvdm
- Full Name: David vd Merwe
- Nickname: David - Hillbilly
- Home Town: West Coast
- Has thanked: 4 times
- Been thanked: 48 times
Have it diagnosed ASAP. My 2.7 started leaking where the throttle shaft goes into the pump. Problem is that at some stage it starts pulling air back through the same seal into the pump. It ate the inside of the pump up in no time.
Original repair would have been around 2K. But with the entire pump innards having to be replaced, it came to 4K.
Hope you get it sorted soon.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
- Has thanked: 1135 times
- Been thanked: 1046 times
Glad to hear you had no issues on your trip.
Do we have any chance of a trip report?
- Russ Kellermann
Thanks guys,... i'll try see him this week, and take it from there. So far no air being pulled through but ja i dont want it to worsen.
As for the trip report, yes, i'll work on one soon. been crazy back at work and going through a very difficult personal issue, which has taken the wind out of my sails. I WILL try my best, but just bare with me guys. thank you.
Good stuff on the trip ... looking forward to the trip report.
As for the rest brother... strength to you ... get that wind back into those sails!!
- Russ Kellermann
Finally getting around to sorting out the injector pump leak.
I have not called Fanus yet, but i literally just went wast Bosch in CT.
Apparently its leaking at the top shaft.
Rough quotes:
Remove and refit - R3500.00
Full overhaul : R5500.00
or
Seal Kit: R3000.00
Scary shit.
He said i should maybe do injector tips/ nozzels which includes lap the port and clean etc...
R6500.00
It all seems crazy to me if i'm honest. Still, better than a common rail diesel, but ja. I'll be looking for another quote etc.
So basically...:
R10k for pump removal and overhaul or
R16K for pump removal and overhaul as well as injectors etc.
Rough quotes:
or
Seal Kit: R3000.00
Scary shit.
R6500.00
So basically...:
