Brake replacement - labour cost
- Full Name: Florian M.
- Nickname: Flo
- Home Town: Hoedspruit
- Current 4x4: '99 GRX 4500
- Home Language: German
- Has thanked: 42 times
- Been thanked: 34 times
Good morning!
I just had my brakes replaced, all four discs and all pads.
I brought the parts, had just to pay the labour. That was ZAR2000.
Now I wonder: is that reasonable, or a bit on the high side? How long does it take?
- Full Name: SJC
- Has thanked: 237 times
- Been thanked: 203 times
Re: Brake replacement - labour cost
Seems very high. I got a quote for R2k labour to replace main bearing seal, which involves removing the gearbox.
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
NO Fanus you just ripped a oak off
its a very intense and specialized job to replace that agents only rear main oilseal
the correct way is to remove sump aswell and then fit new seal then refit sump
- Full Name: SJC
Thats why i say that replacing brakes should not cost that much...
- Nickname: Flo
I forgot to mention that I was brought home by the garage, so you could add half an hour of working time.
How long does it take to replace all four discs plus the pads?
- Full Name: SJC
And how is that?Wilkie wrote:true but you still ripping an poor oak off....
- Full Name: SJC
I got a quote recently to have my td42 bakkie serviced. Full service which included diff oils, brake pads, radiator flush etc. The total for the labour was R1800.Florian320 wrote:I forgot to mention that I was brought home by the garage, so you could add half an hour of working time.
The labour amount was increased to R2850 when I asked to also include the main bearing seal replacement..
To change brake fluid and all disks and pads if you have a lift sould be about 2 hours work in my opinion. ...mabe they are making up on the mark up for spares that they lost out on....
