Posts: 2859 Joined: 25 Jul 2012 08:36
Has thanked: 189 times
Been thanked: 270 times
Post
by offroadbiker » 07 Apr 2016 08:11
Is there a similar connector to a Brad Harrison, just smaller for thin wire??
Tx
Posts: 7590 Joined: 29 Aug 2010 13:07
Current 4x4: Nissan patrol 4.8 GRX 2005 Toyota 2.7 legend 35 LWB 4X4
Has thanked: 802 times
Been thanked: 562 times
Post
by Tinus lotz » 07 Apr 2016 09:09
Nee jy gebruik n 45a b/h vir dun draad wat is die aplikasie?
Post
by offroadbiker » 07 Apr 2016 09:18
wat de... is 'n 45a???
LED ligte op my awning, so ek plug dit in as roofrack op is en ontkoppel as roofrack afkom.
Posts: 1831 Joined: 12 Jan 2015 13:26
Has thanked: 451 times
Been thanked: 724 times
Post
by iandvl » 07 Apr 2016 09:36
offroadbiker wrote: Is there a similar connector to a Brad Harrison, just smaller for thin wire??
Tx
I think you're looking for this:
http://www.4x4direct.co.za/electrical-p ... p-1893.htm
Stefan
Posts: 1692 Joined: 28 Apr 2009 08:43
Full Name: Stefan de Villiers
Nickname: Stefan
Has thanked: 175 times
Been thanked: 50 times
Post
by Stefan » 07 Apr 2016 10:41
suspect Tinus was referring to 45A (Ampere)
I like the Deutsch connectors for low current applications.
2 pin Deutsch Male and
2 pin Deutsch Female
Post
by iandvl » 07 Apr 2016 10:45
Yes - that would also work. For LED applications, I'd probably go Hella plugs though.
Post
by offroadbiker » 07 Apr 2016 11:09
Thanks, this helps a lot
Where can I get this except for 4x4 Direct, postage more than actual item....
Stefan
Nickname: Stefan
Post
by Stefan » 07 Apr 2016 21:06
I haven't been able to find them anywhere else
Wilkie
Posts: 1402 Joined: 24 Feb 2014 15:33
Full Name: Errol Wilken
Nickname: Wilkie
Current 4x4: 1999 4.5 GRX Nissan Patrol 2004 BMW 3.0D X5
Has thanked: 69 times
Been thanked: 92 times
Post
by Wilkie » 07 Apr 2016 22:55
Have a look at Makro
Posts: 3461 Joined: 10 Jun 2009 16:58
Current 4x4: 1982 Datsun Safari 2,8 aka LOBO; [1,300,000 Km verby !] '99 PATROL 4,2 diesel. 2012 Jimny [SWAMBO se Kantoor-toe]
Has thanked: 299 times
Been thanked: 160 times
Post
by Kagiso II » 08 Apr 2016 00:07
H'lo Dirk .. 4x4 Direct het mos hul 'whare house' hier in Boksburg ??? Kom kry sommer by hulle
ek het soortgelyk gehad met Boezman waar 'k draadjies moes gereeld afhaal .. ek het sommer "choc block" gebruik... as daai rooi/ swart goete toe beskikbaar was sou 'k diè gebruik het
Users browsing this forum: Semrush [Bot] and 1 guest
