3.0 DI exhaust
PaulvdMerwe
Full Name: Paul van der Merwe
Nickname: Paul
Home Town: Graaff Reinet
Current 4x4: 2001 Patrol 3.0 DI GRX
Been thanked: 6 times
3.0 DI exhaust
Post by PaulvdMerwe »
More manne,
So my nuwe turbo is oppad maar ek het besluit die exhaust moet sommer in terwyl ek nou besig is.
Ek gaan 3" deur sit maar is daar geen bokse in nie. Of sit mens maar n free flow box in die agterste posisie?
Re: 3.0 DI exhaust
More Paul
Ek dink die manne met die 3.0's sit n klein freedlow boksie heel agter in dan klink hy baie mooi.
Goeie call op die 3" exhaust!, dis die cheapste mod wat mens kan maak vir die meeste kraf plus jou engine gaan dit like!
gupster
Full Name: Barry Guppy
Nickname: Baz
Home Town: Hibberdene
2005 Nissan Patrol 3.0 GR
Has thanked: 136 times
Been thanked: 31 times
Re: 3.0 DI exhaust
Post by gupster »
Hi Paul. I too want to fit a 3 inch exhaust on my Patrol so am watching this topic for advice from the members. I was thinking of going to Power flow in Durban to have it done but is there a better option? I also believe that being diesel, its pointless to go stainless steel. Is this right?
Have Troll, will travel.
PaulvdMerwe
Nickname: Paul
Re: 3.0 DI exhaust
Michael, Gupster
Thanks for the replies.
Yes I hope to get more replies on this tread, since I want to start building that exhaust by Tuesday as soon as my new turbo arrives.
I was in George yesterday and popped in at the local Powerflow shop. They wanted to nail me R5500 for a mild steel pipe.
I have a business card in my desk drawer of a place in Bloemfontein that quoted me R2200 for a Stainless steel pipe. (This price did not include fitting)
Since I stay in Graaff-Reinet and we are very limited to what is availible, I decided to buy lengths of 3" pipe and also got a piece what has lots of various bends in it, so I will cut and weld in my workshop.
I also think that since it is diesel, a mild steel system should be fine.
Michael Thanks for your input. I value all your comments and prompt reply. I would like to have more comments on this tread. Otherwise I will go completely free flow and if I find it to be noisy, I will install a free flow box next month. Doing a turbo and exhaust in one month drained my resources a bit.
Re: 3.0 DI exhaust
Ok if you search 3 inch exhaust you will find a lot on this topic . You can def go clean pipe all the way sounds great i like it and works well
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: 3.0 DI exhaust
Post by JoshJ »
I installed a 3" exhaust about 4 weeks ago. Mild steel is fine. I installed a freeflow box only for a bit of added beat. The 3.0 liter is very quiet. The down pipe is very important if you want to gain on power. Mine is 3 inches from the turbo flange. I gained +-66 nm just from the exhaust. You can check my xhaust post under "my zd30 had some tlc. " :mytwocents:
Being alive is a Blessing!!
Joshua
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Re: 3.0 DI exhaust
Post by Stefan »
Mine is still standard, but with all the positive feedback my Patrol will be getting one of these in the not too distant future.
Re: 3.0 DI exhaust
Forgot to ad guys are paying 2200 to 2600 for complete 3 inch installed up here :thumbup:
Has thanked: 249 times
Re: 3.0 DI exhaust
I paid R2200 for a 3" pipe from turbo to back. (Mildsteel). Same place Josh did his in Nigel. Just dont go there on a friday.
They close shop for an hour to go pray, if they not finish you have to wait for them to come back... WWW
DaleB
Full Name: Dale Barr
Nickname: Dale
Current 4x4: 2008 Patrol 3.0Di
Has thanked: 1 time
Been thanked: 7 times
Re: 3.0 DI exhaust
Post by DaleB »
I had a stainless 3 inch pipe with no box fitted. Can't remember cost? Was around 2k? The fit is tricky! Lots of interesting bends and space is quite tight in some areas.
Power wise the diff is amazing! He spools unbelievably fast... wants to rev! A bit noisy for my liking and I will have a box fitted at some stage. He also has a vibration at 2000rpm that needs fixing!
