Wanted: Double filler neck
- Newbie
- Full Name: Jens Dietzel
- Nickname: Jens
- Home Town: Windhoek
- Current 4x4: Nissan Safari 4.8 2003
Landrover Series IIIs - Home Language: German
Looking for a double/dual filler neck like originally fitted in the models with sub tank.
I have an Y61 2003 4.8 without sub tank and now I have to weld my own one. But it would be great if someone has a scratchyard with a Patrol with this part.
Otherwise I have to buy an aftermarket filler neck and fit it in my existing single filler neck plate.
Does anyone have one?
Thanks in advance
Jens
Thanks in advance
Jens
- Full Name: HS
- Nickname: Picasso
- Current 4x4: Nissan Patrol
- Has thanked: 10 times
- Been thanked: 45 times
Re: Wanted: Double filler neck
I see you are from Namibia.
The best bet in South Africa ... I guess would be
David Vollschenk / ow ait tree for nein nein won fife ait ait
Good luck
Good luck
Dawid got a 2003 4.8 in the other day he will be able to help you with every thing
- Newbie
- Nickname: Jens
Do you maybe have an email address from David?
I would like to send him some pics what I need exactly.
Otherwise I will just phone him. Where is he located in SA?
Thank you so much for your help!
And yes, even in Namibia there are a few Patrols
jens
jens
He is in bela bela or the old warmbaths
Why dont you get the complete sub tank system from him ???
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Has thanked: 193 times
- Been thanked: 275 times
- Newbie
- Nickname: Jens
Good Morning,
you are GREAT
The original subtank with 32 litres is too small, due to the thirst of the 4.8s I need more for trips to the remote areas in Namibia/Botswana.
And I do not want to put more than 4x 20l jerry cans on the roof carrier.
We will see
Jens
you are GREAT
We will see
Jens
- Has thanked: 1136 times
- Been thanked: 1047 times
Jens, unless you get very creative with an extension that goes over the prop-shaft, the biggest sub-tank you can fit is around 55-60l.
I am not sure it's worth the trouble, depending on how much more a custom tank will cost than the standard one?
- Full Name: Ian Temperley
- Been thanked: 92 times
No Just too much SlaapStad air, standard tanks are 90L and 35L making a total of 125L as far as I understand
Users browsing this forum: No registered users and 13 guests
