TOOLBOX FOR TOUR
KOOS BEST
Nickname: Kosie
Home Language: TWEETALIG
TOOLBOX FOR TOUR
Post by KOOS BEST »
What tools do you guys pack in when you go on a tour.
I pack the following:
Assortment of 12 volt fuses
1 x 500ml Anti Freeze
1 x 500ml Brake Fluid
1 x 5lt Oil
1 x 500ml Radiator seal
1 x Diesel filter ( for zd 30)
20m 2MM gauge wire(bloudraad) and plier
Assorted cable ties
1 x Duct Tape
1 x Insulation Tape
1 x Warning tri angle
1 x Glue stick
1 x 500ml hand cleaner
1 x Pratley epoxy steel
1 x Q bond ultra strong repair kit(powder and adhesive)Excellent stuff, seen a brake pipe been repaired with this
1 x Q bond super glue
1 x Q20
1 x Electronic contact cleaner
assortment of elastic bands
Screwdriver set
Tow rope
Spanners SET 8-24
Socket Set 8 - 24
Vice Grip
Heavy duty shifting spanner
1 X Stanley knife and blades
Land Rover Discovery 3 TDV6
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Re: TOOLBOX FOR TOUR
Post by Jules »
I just take my WIFE and a single malt whisky :woo:
Vaatjie
Full Name: Francois Slabbert
Nickname: Faffa
Home Town: Welgemoed
Current 4x4: 2006 4.8GL PATROL
Post by Vaatjie »
Mooi Koos. Ek sal bietjie my toolbox moet aanvul.
Tjaart
Nickname: TJ
Current 4x4: Patrol 4500 GRX
2000
Post by Tjaart »
Wow
It looks as if you want to repair your Patrol and keep on going until no one can find you!! Looks pretty thorough to me! :thumbup: . Onthou net K@Kpapier en vuurhoutjies, dan is jou reg!! :oldtimer:
THE BRAVE
says
Aut PATROL aut nihil
Aut vincere aut mori
1x5l olie is te min vir 'n Patrol - myne benodig 9.8l vir 'n olie vervanging.
KOOS BEST
Nickname: Kosie
Post by KOOS BEST »
Dit is nie vir vervanging nie , maar vir nood, eitlik moet dit n multidoel olie wees soos wat korporasies verkoop aan boere, totaal meerdoelig ,vir enjin, ratkas en diffs indien daar n lekkasie of iets ontstaan.
Aries66
Full Name: Louis Naude
Nickname: Aries66
2011 Navara 3.0V6 V9X
Post by Aries66 »
Hi Koos.
Met ons onlangse trip het ek die volgende ook by gesit.
20 "Stainless clamps" verskeie grootes.
2x 40mm "universal Radiator hoses" elk+- 0.5m
2x 30mm "Universal Radiator/water hoses" elk+- 0.5m
3m 20mm Rubber tubing.
Verskeie "bends" in die verskuie diktes pyp.
1 stel spaar V-Belde.
3 Staal saaglemme 18/24/28 en een universal handvatsel.
2x 200ml Silicone sealer (CAR)
"Fueler gauge"
15m Plat geweefde rol tuinsang met "fittings " van al die verskillende grote krane.
Pratley Putty.
16" en 18" Wheel spanners.
Waterpomp tang, standaard groot tang, 3 verskillende grote side cutters een wat 16mm kabel eenmalig kan afsny (permanent byderhand)
Daar was nog so paar ander klien goed wat ek nie nou kan onthou nie. Die een laai van my laaistel was net vir gereedskap en .....
Groete.
Louis.
KOOS BEST
Nickname: Kosie
Post by KOOS BEST »
Dankie Louis , dit is noodsaaklike goed die van jou , sal soos Vaatjie noem my toolbox ook moet aanvul.
Tjaart jou goeters het ek altyd naby!!, daarsonder is jy in die @#$
Louis, daai wat jy noem "veskeie bends en diktes pyp" , brei so n bietjie uit asb soos watter pype ens , sal graag wil weet.
Groetnis
Engel
Full Name: Herman Engelbrecht
Nickname: Engel
Home Town: Kempton park
Current 4x4: MQ patrol
Gu Patrol
Triton
Home Language: maakiesaakie
Post by Engel »
ek sal my lysie soek wat ek op die bushmechanics vir die manne gee!! Daar kom nog so paar goeters by! Dis maar die idee solank jy weet wat om met die goed te maak! so vinnig,
Regulator
brake line
gasket maker
2 wheel bearings [take no space]
universal
pratley steel
thermostat
:think:
lys is op kantoor
Herman 0824453301
herman@angeloffroad.co.za
