Replacement studs
Has thanked: 189 times
Been thanked: 270 times
Replacement studs
So I need to replace all the studs on the GQ, anybody else that have replaced theirs? If I remember correctly Grant said he replaced them previously with that of a Landcruiser???
Re: Replacement studs
So the 96 Cruiser stud will fit...
Nissan stud with nut = R232 x 24 = R5,568
Toyota stud with nut = R106 x 24 = R2,544
Toyota stud with nut from Nuts en bolts = R61 x R24 = R1,440
Been thanked: 430 times
Is the Toyota and Nissan thread the same?
I think the Nissan uses 12 x 1.25 thread
Yep, but if I replace the stud and the nut (all 24 :doh: ) then its not a problem, Toyota is the "more universal" 1.5 thread so much easier and cheaper to replace the nut....
Makes sense as its way harder to find Nissan nuts in the event that one gets lost.
And I can get 10 for the price of 1 Nissan nut - that is ridiculous :naughty:
Been thanked: 473 times
Why you want to replace the studs?
Because Lombard tyres screwed them up :oldtimer:
Ahhhhhh.... sheeeeeeeeeeet man
I would fit the cruiser studs and nuts again for sure. In fact I'm going to do mine too one of these days. Nissans threads are good that you get a better bite on the rim due to the finer thread, but can be a pain in the donkey if you ever loose a nut. Get studs slightly longer if you can to compensate for the 6mm spacer !!
Dirk, give Speedy Nut and Bolt a call?
Keep in mind that the finer thread is stronger, although it's probably not necessary.
Return to “14. Rims & Tyres”
