Snomaster fridge at makro
- Schalk
- Full Name: schalk willem
- Nickname: schalkgrobler
- Home Town: randburg
- Current 4x4: 2006 d22 hardbody 4x4 D/C
- Home Language: afrikaans
- Been thanked: 3 times
Morning i saw on makro's website snomaster 40l 220v is going for R3500 not a bad price.
Can you run this from an inverter?
https://www.makro.co.za/sports-and-outd ... r-292734EA
d22 warmachine nuff said...
- Chris Skinner
- Full Name: Chris Skinner
- Nickname: Chris
- Has thanked: 10 times
- Been thanked: 53 times
Re: Snomaster fridge at makro
This is probably bad advertising - I am pretty sure this unit also takes 12v... so does not need an inverter. If no 12v, it will run with an inverter yes at 220v.
- Been thanked: 430 times
I think ithis is a 220v only freezer, I alost baught one a while back when I thought it must be 12v and 220v. I did closer investigation and found on the Snowmaster website that they actually make some 220v only
- Chris Skinner
- Nickname: Chris
Ok, if that's the case then I would recommend getting 12v/220 model if you want to use it for your vehicle!
This for a number of reasons, not least that a good inverter will set you back more than the delta in cost for the 12v fridge and that the inverter also has a power consumption aspect, which you don't need!
- JoshJ
- Full Name: Joshua Joubert
- Nickname: Joshua
- Current 4x4: 2004 GL TD42
- Has thanked: 81 times
- Been thanked: 96 times
Jip. Agree with Chris. A proper Overland or 4x4 fridge is designed spesifically for this task. The great once have a danfoss compressor that can run at any agle. Has one moving part to ensure better reliability. And use very little amps. Normal caravan fridges needs to be level to operate. And they are very heavy on power. So thats mainly why you pay the same money for a small 40liter fridge than you payed for your fancy 460litre kitchen fridge.
Being alive is a Blessing!!
Joshua
Joshua
- Full Name: SJC
- Has thanked: 237 times
- Been thanked: 203 times
SnoMaster 50 Litre Super Refrigerator (Gas & 220v) - R 3,199 on Takelot.com:
http://www.takealot.com/snomaster-50-li ... ID40900194
Nee fanus lees wat josh geskryf het nie die regte ding nie . Daai is n amoniak een net 30 grade onder ambient
- JoshJ
- Nickname: Joshua
Very good price. Good fridges also.
Joshua
Joshua
