Kingpin shims needed
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Has thanked: 51 times
Been thanked: 10 times
Post by NMAD »
I am looking for anyone that can help me with the shims for the king pin bearings to set the pre load correctly.
I currently have the 0.5mm shims and I am urgently looking for the 0.2 mm shims or less. Need 4. The agents don't have any stock in my area CT only in Jburg :think:
Andre Steyn
Full Name: Steyn
Nickname: Andre
Home Town: Rustenburg
Current 4x4: 99 Nissan Patrol Y61 4.2 Turbo intercooled Station wagon or Nissan patrol 4.2tdi pick up and now wifey's 2007 4.8 grx added to the family
Been thanked: 11 times
Re: Kingpin shims needed
Post by Andre Steyn »
You could buy shim stock and make them yourself it will be quite alot cheaper than the agent. The shim stock comes in roll of various thicknesses.
I agree with Andre... they are dead easy to cut and make yourself at a fraction of the cost
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
I agree..you can buy them in a box and they come in an assortment of thicknesses
try you local bolt and nut distributors
Goodluck :salute:
davidvdm
Full Name: David vd Merwe
Nickname: David - Hillbilly
Home Town: West Coast
Been thanked: 48 times
Post by davidvdm »
Do new kingpin bearings come with a set of shims needed to do everything you need to do. I removed a shim from top and bottom kingpins on both sides on the Sani, and have them laying here, but not sure I am going to need them in future when I replace the kingpins.
I have no idea what the thicknesses are that I removed, I just took whet felt like the thinnest shims out and it sorted my floppy wheel problem.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
As far as I know the bearings don't come with new shims. Just also check as I seem to recall hearing that the kingpin bearings are the same as a golf wheel bearing (not sure if front or rear ). You will need those shims back in there once the new bearings are fitted in to get the correct Nm on the steering, otherwise your steering will not return to centre and you will go round and round and round and round.................. :lol:
davidvdm
Post by davidvdm »
Gees, see if you can find out about that golf bearing deal!!! I have this horrible item on my "to do" list that is going to releave me of close on R2K with wheel bearings, from the land down under.
But then I also get the wipers and seals, if I remember correctly.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
davidvdm
Post by davidvdm »
I better also go find those shims I removed. They are laying about between all the goodies that got picked up from the workshop and dumped into the store.
Also still looking for anybody needing a front diff for a HB, some torsion bars and drive shafts with manual free wheel hubs, disks and callipers. I see I had some bites in OLX and Junkmail, but my phone was ignoring that Gmail account and I missed them.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Post by NMAD »
Flip thanks guys, that's a brilliant idea to make them up as you have said! :woo: :thumbup:
After greasing mine my steering is so loose it's all over the place and it has a slight wobble at 100km so need to tighten those bearing up.
davidvdm
Post by davidvdm »
Adding shims makes it more loose. Removing them makes it tighten up.
Mine had a wobbly front end, being a 80"s model and probably never looked at, I removed some shims and it's great now.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
