ZD30-DI changes to ZD30-CRD
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Post by JoshJ »
Hi Guys,
I came across this Nissan manual that explains the changes made to the ZD30 Patrols from 2007 for those who are interested.
ENGINE (Diesel) ZD30 e-learning
https://www.google.co.za/url?sa=t&sourc ... DI_NNmBYOw
Being alive is a Blessing!!
Joshua
JoshJ
Nickname: Joshua
Re: ZD30-DI changes to ZD30-CRD
Post by JoshJ »
I read 28pages of threads and lots and lots of posts on the Aus Patrol forum this weekend on the CRD motors. Well I can tell you that the changes made in '07 made all the difference. Guys are driving std and modified CRD's with 200-300 000k's without problems theres a few over 300000k's still going. Yes their is breakages reported but none of the tipical hand granade failures. They are also few and far between.
The new commonrail electronic diesel injection with new ECU was a game changer. Boost is much better controled. Guys run 3" freeflows with Dastec and chip it chips with great success and they make good power with low EGT's. Boost running at 1.5 bar Controled. No spikes. Some guys run with daws valves and some without. All and all I was very impressed. :salute:
If anyone is having trouble with the link you can pm me with your email adress and I will gladly mail you the pdf.
Joshua
Thanks for this josh great info brother :salute:
Been thanked: 473 times
Very good info Josh.... thank you
jonathan
Full Name: Jonathan Venter
Nickname: jonathan
Home Town: Jacobsbaai
Current 4x4: 2005 4.8 GRX
Has thanked: 9 times
Been thanked: 43 times
Post by jonathan »
So would this one be the newer CRD?
http://www.gumtree.co.za/a-cars-bakkies ... 0737080309
If so, I must say the Dark Side is tempting...
JoshJ
Nickname: Joshua
Post by JoshJ »
The model sounds right. But to be sure you can open the bonnet and see this:
Then its the CRD.
If you see this:
unnamed (1).jpg (47.06 KiB) Viewed 17311 times
Then its the old one.
Joshua
jonathan
Nickname: jonathan
Post by jonathan »
Thanks Josh, that's great to know. I'll keep it in mind if I wander any further down the dark path... :biggrin:
JoshJ
Nickname: Joshua
Post by JoshJ »
With a properly tuned unichip youlle be making more power than your 4.5 plus youll be saving at the pump. The darkside is better than you think :lol:
Joshua
JoshJ
Nickname: Joshua
Post by JoshJ »
This is Dyno results from a CRD patrol. Dyno and unichip was done by boksburg SAC. This is on the wheels. Not flywheel. And 33" KM2 MUDS.
Joshua
Daai is lelik as mens 35% by tel beteken dit daai koolstoof beweeg naby aan n regte kar se krag ens.... :rolling:
