Wheel Alignment
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Wheel Alignment
Post by Clem »
How often should it be checked - if ever - on a GU? I never bother on any of my Land Rovers (whether coil or leaf sprung).
Re: Wheel Alignment
At least every 10 000 when you rotate and balance your wheels
Re: Wheel Alignment
It never goes out though. ....
Clem
Nickname: Clem
Re: Wheel Alignment
Post by Clem »
Tinus lotz wrote:It never goes out though. ....
That's what I thought.
Re: Wheel Alignment
On my previous 4.8 l checked it every 5000 form 12000 to 150000 not once did it move ...lol
Carel
Full Name: Carel Vos
Nickname: Carel
Home Town: Germiston
Current 4x4: 84 Safari
2001 Patrol 4.5 GRX
Been thanked: 10 times
Re: Wheel Alignment
Post by Carel »
Ek het my alignment so jaar of wat terug laat doen en dit was effe uit gewees. Die diagram wat Autoquip gehad het om die verstelling te doen was egter anders as die wat op my Patrol is, maar die tegnikus kon dit uitsort. Hy het toe gevra dat ek net by Nissan moet uitvind wat die korrekte suspensie moet wees. By East Rand Nissan wou ek met die werkswinkel bestuurder praat, maar hy het gesê dat ek die voertuig moet inboek dan sal hulle kyk of daar fout is??? Ek het die Patrol na so 10 000 km, wat die rowwe paaie van Angola ingesluit het, weer teruggevat na Autoquip en die alignment was baie min uit.
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 20 times
Been thanked: 97 times
Re: Wheel Alignment
Post by David M »
Did my suspension lift 20 000 km ago. Checked the alignment last week as I reckoned it may need attention as the suspension should now have settled. No adjustment required and as it was the same place (twt fourways) they had the record of the previous settings. It hand changed by 100 th's of a degree. Some of the trips done included the wild side of the Transkei and Kalahari.
But balance and rotate those big wheels and tyres every 10 000 km. That was horribly out after 10 000 km.
