VOOR REMME
roelf prinsloo
Full Name: Roelf Prinsloo
Nickname: Roelf
Home Town: Klerksdorp
Current 4x4: Nissan Patrol 5.6L V8 LE Premuim ( Y62 ) 2018
Has thanked: 17 times
Been thanked: 17 times
VOOR REMME
Post by roelf prinsloo »
EK HET BIETJIE OP DIE FORUM GESOEK MAAR KRY NIKS ( DALK IS EK NET DOM )EK HET N 2014 PATROL 4.8 GRX MET 15000 KM OP. HET HAAR SO MAAND TERUG GEKOOP EN WAS AL OP N TRIP SO 1500 KM KAAP TOE,GEEN PROBLEEM. WAS EGTER DIE NAWEER JHB TOE EN NOU STEEK DAAR N PROBLEEM KOP UIT.DIT WIL VOORKOM OF DIE VOOR REMSKYWE WARM WORD EN NIE GOED WERK NIE. DIE PEDAAL SPRING ONDER MY VOET EN EK VOEL DIT OP DIE STUURWIEL.DAAR IS EGTER GEEN PROBLEEM AS DIE REMME WEER KOUD IS NIE. EK HET NOG NIE DIE AGENTSKAP HIER GEKONTAK NIE MAAR WIL GRAAG HOOR OF DAAR NOG OUENS IS WAT DIT ONDERVIND, EK WIL OOK WEET OF DIT DALK DIE REMVLOEISTOF KAN WEES. EK VERSTAAN AS DIE SKYWE GEBUIG IS SAL EK DIE SIMTOME KRY, MAAR WAAROM NET AS HULLE WARM IS?HULLE SAL MOS GEBUIG BLY.
EK HOOP IEMAND KAN MY HELP MET N VERDUIDELIKING. DANKIE
Re: VOOR REMME
Hey Roelf
sounds like your brakes might be bonding ....give graham a call he is in valhalla
is your car still under nissan grantee?
The pedal jumping under your foot is a problem might be abs not working properly? 15000 is about time for new pads . Mabe just check the disks on a skim machine before you change them?
Been thanked: 473 times
Re: VOOR REMME
15 000km on a set of pads should still have a lot of life left on them I think.
It must be something small that is making the nonsense. Possibly an air bubble? I would send it in to Nissan and let them bleed the brakes completely and check the ABS sensors.
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: VOOR REMME
Post by JoshJ »
Cedric, the petrol brake pads dont last as long as the diesels. I am on 30 000km's now. Stil a lot of meat left. Again another area where you safe by drive a koolstoof :lol:
Being alive is a Blessing!!
Joshua
Re: VOOR REMME
:rolling: :rolling: :rolling: :rolling: :rolling:
Josh, you are so right brother...... If only they would be open to saving lots of money !!!
Been thanked: 430 times
Re: VOOR REMME
Roelf,
Jack jou Patrol op en haal een van die voor wiela af. Jy sal dadelik kan sien as jy van voor af deur die rem klou kyk hoeveel vleis jy oor het op jou rem blokkies, dalk is daar iets ooglopend wat jy raak sien wat die probleem kan veroorsaak soos iets wat los is.
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: VOOR REMME
Post by David »
Had the same problem only when going down mountain passes and applying slight braking. A shudder would develop as soon as the disks warmed up.
Solved it by fitting a new set of disks from Power Brake. :thumbup:
Apparently it can also be from deposits from your pads on the disks. Abuse them by going to 100km/h and braking hard down to 40km/h 5-6 times. This should make them hot enough to burn away any deposits :salute:
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Hilux 2,4 4x4 SC Dakar
Been thanked: 26 times
Re: VOOR REMME
Post by Grant »
That is why we drive diesels, No need for brakes on down hills as we have the compression to assist. :rolling: :rolling: :rolling: :rolling: :rolling: :rolling: :rolling:
David
Nickname: David
Re: VOOR REMME
Post by David »
Ag jou g@t ook man! Ons moet briek anders gaan ons vlieg :lol:
Actually the braking with the tiptronic is quite good. I just pop it in manual and shift down and it will keep certain speeds depending in if it is in H or L but must agree it is still a bit fast in L first gear when off road :thumbup:
Re: VOOR REMME
Ons petrols maak net rook op die tyres. ..lol mens moet stop ook.....daai groot bus eet briek blokkies as jy jaag.....
