TB45E Knocking when starting ...and other bad performance
irfaanharris
Junior Member
Junior Member
Full Name: Irfaan Ivan Harris
Nickname: Faanie
Home Town: Kimberley and Riyadh
Current 4x4: Patrol SGLE y61 tb45e
Post by irfaanharris »
Hello all,
I have replaced my TB45E engine and it has two problems.
I have since switched to only high octone (95)
Problems 1 - when starting tye car in the morning, the engine revs high, and as there is initially low oil pressure, the big end knocks. for 1 second.
I believe it has something to do with fuel dripping from an injector. at night. also happens if vehicle not running for a couple hours.
Problem 2. Pinking, low power on long uphill, and sort of resonating engine sound when decelerating? no exhaust backpressure? or faulty advance / retard?
Problem 3..... where is the Knock sensor - I would like to check if it is 460megaohm. / check wiring.
comments will be most appreciated.
Thx
Faanie
Irfaan Ivan William Harris
+966 505 414 576
or +27 21 0351409 at night it auto connects to me daytime via operator at office
Re: TB45E Knocking when starting ...and other bad performanc
Is the problem not the fuel pump as well.
When I replaced my fuel pump I can still drive uphill in 5th gear.
PathMaker
Full Name: G
Nickname: PathMaker
Home Town: Centurion/Pretoria
Has thanked: 13 times
Been thanked: 46 times
Post by PathMaker »
Hi irfaanharris
Herewith Graham's advice:...
Problem 1: Check basic setting on TPS switch, must be at point 0.50mA. Idle compensation valve must be set to 20%. Distributor must be set to 5 degrees. All must be set when car is at running temperature.
Problem 2: This should sorted by correctly settings for problem 1.
Problem 3: Knock sensor is on the right side of the engine under the intake manifold but a electronic diagnostic test can check if this is faulty.
P.S. All petrol Patrols should be running on the highest octane fuel available in this country or even better put in Octane boost on every tank of fuel.
Thanks, hope this helps. If not, an if you're in the area, bring it in, and I will do these checks for you.
Graham & Vanessa :salute:
Graham will fix all your Patrol problems! :thumbup:
Has thanked: 61 times
Been thanked: 257 times
Hi Irfaan
Is this car in Kimberly or in Riyadh?
