Pintle Hooks
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Pintle Hooks
Post by Clem »
Guys,
Has anyone ever found a suitable hook for the GU Patrol 2005+ ? I am thinking of maybe switching my Metalian trailer to an eye setup (simple bolt-off, bolt-on if I can get the right part from Knott). Not sure. Don't like the clonk-clonk idea....
Re: Pintle Hooks
Clem, the pintle hook that fits on the Y60 almost fits on the earlier y61. The bolting pattern is identical, but the Y61's rear step is slightly higher, and thus the pintle hook does not fit unless you are prepared to do some surgery.
However on the face-lift model like yours, the bumper has been extended and the pintle should fit again.
I posted a thread in the classifieds section with a link to a supplier, but they are very expensive and I think your best bet would be to try and get a second-hand one from David.
Clem
Nickname: Clem
Re: Pintle Hooks
Post by Clem »
Peter Connan wrote:Clem, the pintle hook that fits on the Y60 almost fits on the earlier y61. The bolting pattern is identical, but the Y61's rear step is slightly higher, and thus the pintle hook does not fit unless you are prepared to do some surgery.
Thank you Peter. Which David would that be? Sorry...a bit thick here....
Been thanked: 473 times
Re: Pintle Hooks
I think he means David Volsckenk in Bela Bela
http://www.patrol4x4.co.za/memberlist.p ... ile&u=3024
Clem
Nickname: Clem
Re: Pintle Hooks
Post by Clem »
ricster wrote:I think he means David Volsckenk in Bela Bela
Thanks Cedric.
Re: Pintle Hooks
The very one
